Difference Between Driveline Cat. 2 & Cat 3
   / Difference Between Driveline Cat. 2 & Cat 3 #1
newholland4me
Ok, so I am doing my research and according to NH TZ25DA booklet the rotary mower recommended is a 48" with a Category II driveline. I have found a good deal on a 48" mower with the correct hitch category, but with a driveline category III. What is the difference between the categories?
TIA
   / Difference Between Driveline Cat. 2 & Cat 3 #2
TIA
By drive line are you talking about the PTO shaft? Cat II to Cat III 3 point hitch is higher horse power tractors and larger hitch pins. PTO shaft I have no idea.
Well, I am not sure. Here is copy of specs. for mower that is recommended for my TZ25DA:
Hitch category: I
Cutting width: 48
Driveline category: II
Gear box rating: 30
Drive requiremt: 540 rpm PTO
Sorry for being so :confused: but I am a girl with limited understanding of all the mechanical info.
Hope this helps. The one mower I found has all these specs., but driveline category III. Hence, my question.
Thanks for your help. :)
   / Difference Between Driveline Cat. 2 & Cat 3 #4
Cat 3 shaft has a high horsepower rating. It will work fine.
   / Difference Between Driveline Cat. 2 & Cat 3 #6
Typically when referring to cat I, II, III etc on d-lines designates it as a metric d-line (bondioli, pavesi, etc). The cat can normally be figured out by measuring the bearing cap diameter. cat I is 7/8, cat II is 15/16, cat III is 1 1/16, and so forth (or the metric equivelent). These will mostly be the tri lobe style d-lines, while the oval metric d-lines are an altogether different cat designation. On the sae square style d-lines they are cat 6, 12, 14, etc. cat 6 is 31/32, cat 12 is 1 1/16, cat 14 is 1 1/8 and so forth. Like the previous post the higher the # the larger the bearing cross so cat III is just fine for the application.
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
Miles read : 112,969 (A50323)
Miles read ...
24008 (A53422)
24008 (A53422)
2014 MACK CHU DAY CAB (A53843)
2014 MACK CHU DAY...
