Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ?
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ?
My issue is I was using Cub Cadet oil also in 2015 for the slightly used mower I bought. But that is 10w-30 oil. So because I would also use the unit with a snowblower in Wisconsin winters . . I changed out to 5w-30 Havoline. But at the same time I was changing the oil in the subcompact and switching to synthetic mobil because it was such a great value ( after rebate it was and is again less than 10 bucks a gallon). So I start thinking if the synthetic acts as an all season oil for the subcompact . . . could it do the same for the kohler gas engine . . . which is why this thread started.
Full synthetic name brand product for 2.50 a quart and if its ok to use in gas engines . . It gives a bunch if added pourability and all season gains.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #22
$11.99/qt is an awful high price for a non-synthetic oil. I realize you don't use much but just the same.......
Of course, you're right. When I bought my Toro ZTR, that's the oil that my dealer stocked and sold for it. But he quit stocking the Kohler oil; said he had to order too large an amount at a time. So I've just stayed with it, even though I hae to order it at a very high price. But I notice they claim it's rated for diesels also.
Just curious . . On the front of the container is it called diesel engine oil or engine oil for gas engines?
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #24
To quote the label on the container:
KOHLER
SAE 10W-30
UNIVERSAL ENGINE OIL
API Service CF, CF-4, CG-4, CH-4/SH, SJ
FOR USE IN OVERHEAD VALVE EHGINES GASOLINE, GASEOUS FUEL OR DIESEL POWERED
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #25
Look for S or C ratings. ( Service / Commercial )
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
