Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ?
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ?
My issue is I was using Cub Cadet oil also in 2015 for the slightly used mower I bought. But that is 10w-30 oil. So because I would also use the unit with a snowblower in Wisconsin winters . . I changed out to 5w-30 Havoline. But at the same time I was changing the oil in the subcompact and switching to synthetic mobil because it was such a great value ( after rebate it was and is again less than 10 bucks a gallon). So I start thinking if the synthetic acts as an all season oil for the subcompact . . . could it do the same for the kohler gas engine . . . which is why this thread started.
Full synthetic name brand product for 2.50 a quart and if its ok to use in gas engines . . It gives a bunch if added pourability and all season gains.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #22
$11.99/qt is an awful high price for a non-synthetic oil. I realize you don't use much but just the same.......
Of course, you're right. When I bought my Toro ZTR, that's the oil that my dealer stocked and sold for it. But he quit stocking the Kohler oil; said he had to order too large an amount at a time. So I've just stayed with it, even though I hae to order it at a very high price. But I notice they claim it's rated for diesels also.
Just curious . . On the front of the container is it called diesel engine oil or engine oil for gas engines?
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #24
To quote the label on the container:
KOHLER
SAE 10W-30
UNIVERSAL ENGINE OIL
API Service CF, CF-4, CG-4, CH-4/SH, SJ
FOR USE IN OVERHEAD VALVE EHGINES GASOLINE, GASEOUS FUEL OR DIESEL POWERED
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #25
Look for S or C ratings. ( Service / Commercial )
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
Quick Coupler (A53316)
Giyi 78" Grapple (A53316)
Giyi 78" Grapple...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2017 CHEVROLET SILVERADO 2500HD (A55745)
2017 CHEVROLET...
2017 Ford F-250 Ext. Cab Pickup Truck (A55788)
2017 Ford F-250...
