Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ?
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ?
My issue is I was using Cub Cadet oil also in 2015 for the slightly used mower I bought. But that is 10w-30 oil. So because I would also use the unit with a snowblower in Wisconsin winters . . I changed out to 5w-30 Havoline. But at the same time I was changing the oil in the subcompact and switching to synthetic mobil because it was such a great value ( after rebate it was and is again less than 10 bucks a gallon). So I start thinking if the synthetic acts as an all season oil for the subcompact . . . could it do the same for the kohler gas engine . . . which is why this thread started.
Full synthetic name brand product for 2.50 a quart and if its ok to use in gas engines . . It gives a bunch if added pourability and all season gains.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #22
$11.99/qt is an awful high price for a non-synthetic oil. I realize you don't use much but just the same.......
Of course, you're right. When I bought my Toro ZTR, that's the oil that my dealer stocked and sold for it. But he quit stocking the Kohler oil; said he had to order too large an amount at a time. So I've just stayed with it, even though I hae to order it at a very high price. But I notice they claim it's rated for diesels also.
Just curious . . On the front of the container is it called diesel engine oil or engine oil for gas engines?
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #24
To quote the label on the container:
KOHLER
SAE 10W-30
UNIVERSAL ENGINE OIL
API Service CF, CF-4, CG-4, CH-4/SH, SJ
FOR USE IN OVERHEAD VALVE EHGINES GASOLINE, GASEOUS FUEL OR DIESEL POWERED
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #25
Look for S or C ratings. ( Service / Commercial )
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
