Diesel engine with a miss.
/ Diesel engine with a miss. #22
My 4020 sounded like it has a miss when the lift pump was going bad. It idled rough and didn't have the power when it was called on.
/ Diesel engine with a miss. #23
ULSD (the fuel you get now) is very hard on injector pintles on older engines that were designed to run diesel with a higher sulfur content (which is why I recommend a diesel additive like Caterpillar Additive. It provides the lubrication that ULSD lacks. ULSD is also hard on mechanical pumps. Blame it on the tree huggers.
Sounds to me like you dropped an injector pintle.
Thanks for this information it was very helpful.
New fuel, fuel additive, and the problem went away after most of the tank was used up.
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
AGT Industrial SDA-140T (A64127)
AGT Industrial...
generator trailer (A61569)
generator trailer...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
