Diesel engine with a miss.
/ Diesel engine with a miss. #22
My 4020 sounded like it has a miss when the lift pump was going bad. It idled rough and didn't have the power when it was called on.
/ Diesel engine with a miss. #23
ULSD (the fuel you get now) is very hard on injector pintles on older engines that were designed to run diesel with a higher sulfur content (which is why I recommend a diesel additive like Caterpillar Additive. It provides the lubrication that ULSD lacks. ULSD is also hard on mechanical pumps. Blame it on the tree huggers.
Sounds to me like you dropped an injector pintle.
Thanks for this information it was very helpful.
New fuel, fuel additive, and the problem went away after most of the tank was used up.
2019 PITTS CONTENDER LD35-22DC RGN LOWBOY TRL (A64277)
2019 PITTS...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
