Did I get the wrong moly grease for my backhoe/loader pins?
   / Did I get the wrong moly grease for my backhoe/loader pins? #1
XR4140
MO
18 LS XR4140
Grabbed this moly grease, when I got home realized it says lithium. Its dark like im used to. Says NLGI-LB on the back.
Thanks for the help!
   / Did I get the wrong moly grease for my backhoe/loader pins? #2
Somebody help me out here: Where's the downside here?
   / Did I get the wrong moly grease for my backhoe/loader pins? #3
First of all, any grease is light years ahead of no grease. Looks fine to me, remember you are not lubricating high speed bearings here. Lube away.
   / Did I get the wrong moly grease for my backhoe/loader pins? #4
Use it, you will be good. Pay attention to how long it stays in the joint.
I found Wal-Mart SuperTech Marine Grease lasts the longest in my Cat backhoe.
I tried a sporty looking Red synthetic but it ran out of the joints from the heat in the summer.
   / Did I get the wrong moly grease for my backhoe/loader pins? #5
^^^^^ What he said!
Thanks guys. Guess ive never seen moly lithium grease. Im used to the white lithium stuff.
Noob here learning.
Carry on :)
   / Did I get the wrong moly grease for my backhoe/loader pins? #7
I think most of it is lithium base. Look at the moly content. I switched to a 5% moly for my backhoe and it lasts much longer than what I had been using.
   / Did I get the wrong moly grease for my backhoe/loader pins? #8
From a reliable source I read you should not always be switching back and forth from lithium based grease to other based grease. Stick with the same base. Switching once in a blue moon doesn't hurt. As long as that tube says high pressure I would use it and then stick to a lithium based grease.
   / Did I get the wrong moly grease for my backhoe/loader pins? #10
On loaders and backhoes pins I switched to Deere polyurea grease. It's their "best" in a lineup of lithium, lith-moly and then polyurea. Kubota also sells a branded polyurea now and I believe dropped the basic lithium from their line.
The Deere poly is a thicker grease that makes loaders, buckets, pins etc feel as tight as new and it stays there for a while.
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2011 Ford F-150 Pickup Truck (A50323)
2011 Ford F-150...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
