Did I get the wrong moly grease for my backhoe/loader pins?
   / Did I get the wrong moly grease for my backhoe/loader pins? #1
XR4140
MO
18 LS XR4140
Grabbed this moly grease, when I got home realized it says lithium. Its dark like im used to. Says NLGI-LB on the back.
Thanks for the help!
   / Did I get the wrong moly grease for my backhoe/loader pins? #2
Somebody help me out here: Where's the downside here?
   / Did I get the wrong moly grease for my backhoe/loader pins? #3
First of all, any grease is light years ahead of no grease. Looks fine to me, remember you are not lubricating high speed bearings here. Lube away.
   / Did I get the wrong moly grease for my backhoe/loader pins? #4
Use it, you will be good. Pay attention to how long it stays in the joint.
I found Wal-Mart SuperTech Marine Grease lasts the longest in my Cat backhoe.
I tried a sporty looking Red synthetic but it ran out of the joints from the heat in the summer.
   / Did I get the wrong moly grease for my backhoe/loader pins? #5
^^^^^ What he said!
Thanks guys. Guess ive never seen moly lithium grease. Im used to the white lithium stuff.
Noob here learning.
Carry on :)
   / Did I get the wrong moly grease for my backhoe/loader pins? #7
I think most of it is lithium base. Look at the moly content. I switched to a 5% moly for my backhoe and it lasts much longer than what I had been using.
   / Did I get the wrong moly grease for my backhoe/loader pins? #8
From a reliable source I read you should not always be switching back and forth from lithium based grease to other based grease. Stick with the same base. Switching once in a blue moon doesn't hurt. As long as that tube says high pressure I would use it and then stick to a lithium based grease.
   / Did I get the wrong moly grease for my backhoe/loader pins? #10
On loaders and backhoes pins I switched to Deere polyurea grease. It's their "best" in a lineup of lithium, lith-moly and then polyurea. Kubota also sells a branded polyurea now and I believe dropped the basic lithium from their line.
The Deere poly is a thicker grease that makes loaders, buckets, pins etc feel as tight as new and it stays there for a while.
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
71063 (A49346)
71063 (A49346)
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
John Deere Bale Spear (A50515)
John Deere Bale...
1997 GROVE TMS750B 50 TON CRANE (A51222)
1997 GROVE TMS750B...
