John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
I think most of it is lithium base. Look at the moly content. I switched to a 5% moly for my backhoe and it lasts much longer than what I had been using.
/ Did I get the wrong moly grease for my backhoe/loader pins?
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
From a reliable source I read you should not always be switching back and forth from lithium based grease to other based grease. Stick with the same base. Switching once in a blue moon doesn't hurt. As long as that tube says high pressure I would use it and then stick to a lithium based grease.
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
On loaders and backhoes pins I switched to Deere polyurea grease. It's their "best" in a lineup of lithium, lith-moly and then polyurea. Kubota also sells a branded polyurea now and I believe dropped the basic lithium from their line.
The Deere poly is a thicker grease that makes loaders, buckets, pins etc feel as tight as new and it stays there for a while.
