did I break anything?
/ did I break anything? #41
i am having this sinking feeling that I will have a bent valve? can I tell if I remove the rockers will one of them be lower? of could it be damaged, and not noticeable from the outside.
Quite a learning experience this is...
A valve can be bent ever so slightly to make it ineffective, and wouldn't necessarily be noticeable from the outside. If you are absolutely sure the fuel injector timing, the valve timing, and the valve lash are all correct, then it's time to pull the head and inspect the valves.
/ did I break anything? #42
Whatnot,
Heres the real deal on diesel engines.
If you have compression and you have fuel and you have the timing between the two.........it runs.
Simple as that.
You need to figure out what isn't happening. You neither don't have enough compression. Or you don't have the proper fuel delivery.
First determine compression. While the injectors are out have them tested on the bench.
If those tests are within specs then you have a timing problem at the pump or possible lack of delivery from pump (for one reason or another).
There are more rarer things that do and can happen but first things first.......compression and fuel (bench test those injectors).
Test those two things then you'll have a direction you can follow.
/ did I break anything? #43
did you by any chance remove/replace either of the timing gears? Or did you remove/install the camshaft when you did other work? If so you may not have the timing gears 'timed' to each other. This would affect the valves opening/closing timing with regard to the piston stokes.
your video actually sounds that way to me.
I believe the timing is correct. When I changed the liners, I removed the connecting rods from the crank through the side access cover. So I never touched the timing between the cam, crank, and IP.
Anyone know if I could disassemble and modify an injector to be a compression testing adapter? That is the only thought I have about compression testing.
Can you hear the exhaust when it is trying to start? Sounds like it is not sealing. but it also might be a odd system thing being it is a 2 cylinder engine. never worked with one before.
So I also had the head done last year, but did not adjust the valve lash after assembling it. IF I bent the exhaust valves back then (I had to pull start it) can I just change the valves and lap them, or do I need to have the head checked for cracks again?
/ did I break anything? #45
"Anyone know if I could disassemble and modify an injector to be a compression testing adapter? That is the only thought I have about compression testing." end quote
Yes depending on what tools you have available and your own imagination. Do you have an old injector laying about? Though I think it's be easier to start with a blank piece of steel.
Do you have a compression gauge that goes high enough?
/ did I break anything? #46
Diesel compression test KITS are available (I THINK) there should be a pretty standard injector hole size.
see this one from HF, (can be had on sale about 60% off this list price.)
Diesel Compression Tester Set - 14 Piece
On the Video, it also sounds to me like either a BENT valve or the Cam/Valve timing is off enough to be opening a valve when compression stroke is hitting. Could you have bent a valve pull starting it ? (Yes maybe if there was a timing issue or a cam issue.)
There are cylinder leak down testers (the compression tester may be able to do this) I have this one from HF. It works and I diagnosed bent valves on my "non-interference engine" when carbon had built up enough and the timing belt let lose. (expensive problem two heads & top end & front of engine is all new now for me 2K bucks :eek:)
Mark
Thanks, I was looking at that kit. I called a friend, and he came and did some tests, We removed the rockers, with the air compressor supplying air to the intake, we pushed on the valves, it appears that both of the exhaust valves are not sealing. at first thought the cam bad broken or a gear had slipped. but by removing the rockers that removed the timing component.
So now I have to pull the head, and the exhaust valves, and see what is going on there.
Another head gasket.. and probably some valves. But does it seem like this is reasonable?
thanks
Doug
/ did I break anything? #48
I agree with that considering what I heard in the video. Hopefully the seats can be cleaned with new valves and some lapping compound but I wouldn't get my hopes up yet. It might not be perfect but I would hope it would run. Best of luck man.
You are one determined and patient man. I may have called in reinforcements by now.
/ did I break anything? #49
Both exhaust valves!!!!!!!!!WTF?????
Something is definitively f'd up.
The last time you had the head off did you note any marking on the piston tops?
Wasn't there a valve job done on that head? I was sure you said there was earlier in the thread.
Did the machine shop cut the head? Er that is plane the head? If so how much did they take off?
And was it beyond the max that engine can accept?
Is there multiple thicknesses of gaskets the manufacturer uses for the engine?
Two exhaust valves?
WTF
BTY,
Neat trick with the air compressor.
I did not note any marks on the pistons, I did have the head done when I worked on this last September, and they did cut the head. I do not know how much, but I did not know to adjust the valves after this. And may have done this the first time I pull started it?
Only one gasket available, can the seats in the head be replaced? that would take a machine shop to do that work again. I will have to ask how much a head ready to go on the tractor is, sometimes these part prices surprise me both ways..
He also mentioned removing the spring and using a drill and try to get the valve to seat, without removing the head again. He said he has seen that work?? have I got anything to loose trying that?
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
10' Container w/ Side Door (A60463)
10' Container w/...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
