Degree Symbol?
/ Degree Symbol? #1
ray66v
Super Member
Ohio
GC2310,
Is there a way to use the degree symbol in this forum? I have needed one several times, and been frustrated trying to find a solution.
I have tried the usual Windows tricks, and a cut and paste results in a degree symbol with this 1 1/2 in front: ( ー )
A button to make a degree symbol in the tool bar, would be a nice add for future development, if there isn't already an easy way to do it.
/ Degree Symbol? #2
1 1/2* ..........this is how I do it.
/ Degree Symbol? #3
You mean like this 32° or this ° without the number? I picked this out of the Character Map in the System tools tab.
Go to: START>ACESSORIES>SYSTEM TOOLS>CHARACTER MAP then choose the symbol style and scroll down and look for the degree symbol. Not a very friendly way to get there but you can get there.:thumbsup:
/ Degree Symbol? #4
If you are using a full keyboard: Alt + 0176 (on the number pad).
/ Degree Symbol?
You mean like this 32ー or this ー without the number? I picked this out of the Character Map in the System tools tab.
If I cut and paste just a degree sign like that, I get all this: コ
And, if I delete the 1 1/2 before the degree sign, they come right back when I post it.
Maybe it's because I am using Firefox?
I did not think of using the asterisk, that's a reasonable substitute.
/ Degree Symbol?
Okay, I turned on the number lock, and with alt 0176 trick. It produces a degree symbol, as many other cut and paste attempts do. However when I post it, I get this: ー
Deleting the 1 1/2 part is futile, it just returns when I post it.
/ Degree Symbol? #9
I don't quite understand how that works, at least it doesn't for me.
In Windows, you can type any character by holding down the ALT key and then typing the character's four-digit numeric code on the keypad. You must hold down the ALT key for the entire time you are typing the code; you must type on the keypad (not on the number keys above the letters); and you must type the entire four-digit code, including the leading zero, if there is one. If you don't have a separate numeric keypad on your keyboard, like many laptops, this won't work.
/ Degree Symbol? #10
Ok, I get it now. It was originally posted as "Alt + 0176" so I tried typing all of it. If the plus sign had been left out of the directions I would have done it right.
Ken
/ Degree Symbol? #11
I use 32[degF] ... or 0[degC] for my friends to the north.
I can never remember those alt keystroke combinations.
/ Degree Symbol? #12
Sorry guys, I should have been more clear. I do a good bit of technical writing so many of the "Alt +" codes are in my head and second nature.
/ Degree Symbol? #13
Same here. But this is the only site that happens to even though other sites I visit use same BBS software.
/ Degree Symbol? #17
The new version of vBulletin does not like most of the alt codes, the * is what I use...
/ Degree Symbol? #18
Use alt + 248 on the keypad. It makes the ー and saves a button press
/ Degree Symbol? #19
Interesting, looked fine when writing the post. I see what you guys mean...it changes it after you post it. Using opera's browser myself.
/ Degree Symbol? #20
yep thats the problem allright.
