Degree Symbol?
/ Degree Symbol? #1
ray66v
Super Member
Ohio
GC2310,
Is there a way to use the degree symbol in this forum? I have needed one several times, and been frustrated trying to find a solution.
I have tried the usual Windows tricks, and a cut and paste results in a degree symbol with this 1 1/2 in front: ( ー )
A button to make a degree symbol in the tool bar, would be a nice add for future development, if there isn't already an easy way to do it.
/ Degree Symbol? #2
1 1/2* ..........this is how I do it.
/ Degree Symbol? #3
You mean like this 32° or this ° without the number? I picked this out of the Character Map in the System tools tab.
Go to: START>ACESSORIES>SYSTEM TOOLS>CHARACTER MAP then choose the symbol style and scroll down and look for the degree symbol. Not a very friendly way to get there but you can get there.:thumbsup:
/ Degree Symbol? #4
If you are using a full keyboard: Alt + 0176 (on the number pad).
/ Degree Symbol?
You mean like this 32ー or this ー without the number? I picked this out of the Character Map in the System tools tab.
If I cut and paste just a degree sign like that, I get all this: コ
And, if I delete the 1 1/2 before the degree sign, they come right back when I post it.
Maybe it's because I am using Firefox?
I did not think of using the asterisk, that's a reasonable substitute.
/ Degree Symbol?
Okay, I turned on the number lock, and with alt 0176 trick. It produces a degree symbol, as many other cut and paste attempts do. However when I post it, I get this: ー
Deleting the 1 1/2 part is futile, it just returns when I post it.
/ Degree Symbol? #9
I don't quite understand how that works, at least it doesn't for me.
In Windows, you can type any character by holding down the ALT key and then typing the character's four-digit numeric code on the keypad. You must hold down the ALT key for the entire time you are typing the code; you must type on the keypad (not on the number keys above the letters); and you must type the entire four-digit code, including the leading zero, if there is one. If you don't have a separate numeric keypad on your keyboard, like many laptops, this won't work.
/ Degree Symbol? #10
Ok, I get it now. It was originally posted as "Alt + 0176" so I tried typing all of it. If the plus sign had been left out of the directions I would have done it right.
Ken
/ Degree Symbol? #11
I use 32[degF] ... or 0[degC] for my friends to the north.
I can never remember those alt keystroke combinations.
/ Degree Symbol? #12
Sorry guys, I should have been more clear. I do a good bit of technical writing so many of the "Alt +" codes are in my head and second nature.
/ Degree Symbol? #13
Same here. But this is the only site that happens to even though other sites I visit use same BBS software.
/ Degree Symbol? #17
The new version of vBulletin does not like most of the alt codes, the * is what I use...
/ Degree Symbol? #18
Use alt + 248 on the keypad. It makes the ー and saves a button press
/ Degree Symbol? #19
Interesting, looked fine when writing the post. I see what you guys mean...it changes it after you post it. Using opera's browser myself.
/ Degree Symbol? #20
yep thats the problem allright.
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
1 PALLET OF HYDRAULIC HOSES (A66091)
1 PALLET OF...
2012 Dodge Grand Caravan Van (A66738)
2012 Dodge Grand...
PALLET OF HEAVYEQUIPMENT PRESSURE WASHER PARTS (A68842)
PALLET OF...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
10ft Fork Extensions (A66734)
10ft Fork...
