definition of 4wd?
/ definition of 4wd? #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Guys, I have a Yanmar (FF205) that has no 4wd shifter but is a 4wd tractor. My question is what constitutes 4wd? Up on the jacks I have one rear tire pulling and the opposite front tire pulling. this is a newer Yanmar ,1991. thanks, brett
ps, the reason I'm asking is that I'm going to need turf tires soon and dont know about keeping the tire ratio if I am indeed in 4wd (or something like that) all the time.
/ definition of 4wd? #2
I really don't know on a tractor, someone like EFC, or one of the other dealers would know. But I do know on a car or truck, 4 wheel drive just means one of the rear and one of the front is pulling at any one time. That is why they have all wheel drive out there now, then its all 4 wheels is pulling at one time. On two wheel drive they has pos-trac to have both wheels pull at the same time. other wise only one is pulling. So it comes out 2 wd is one pulling, and 4wd is 2 pulling.
/ definition of 4wd? #3
I'm not familiar with an FF205 Yanmar, but if power goes to the front and rear axles you will need to keep the tire sizes correct.
I'd like to see a picture of an FF205. Can you post one?
Dave
/ definition of 4wd? #4
The only difference between "All wheel drive" and "Four wheel drive" as it pertains to automobiles, is that the 4wd vehicle will have a two speed transfer case where the AWD is only single speed. Without locking or limited slip differentials in the axles or some type of brake actuated traction control system the AWD vehicle won't get around any better than the 4wd one. The tractor must have some kind of full time 4wd setup if it does not have a lever to disconnect the front axle. In any case, it should be readily apparent by looking at the front axle of the tractor wether it is 4wd or not. If it is, you will want to properly match the tire diameters to maintain the correct lead ratio.
/ definition of 4wd? #5
<font color=blue>But I do know on a car or truck, 4 wheel drive just means one of the rear and one of the front is pulling at any one time. That is why they have all wheel drive out there now, then its all 4 wheels is pulling at one time.</font color=blue>
On 4 wheel and all wheel drive vehicles, the wheels pull the same. The difference is a 4 wheel drive the driver can select between 2 and 4 wheel drive, and an all wheel drive vehicle is always "in" 4 wheel drive.
What makes only one wheel on the front and rear spin is the "open" differentials in the axles. These allow one wheel to spin faster than the other when cornering. When the power applied to the axle overcomes available traction, generally the wheel with the least traction gets more power applied to it and it spins, which makes it look like your 4 wheel drive is only two wheel drive. A "limited slip" type differential does just that, it "limits" the amount of differential action, providing power to both wheels under most conditions. A locking differential like most tractors have on the rear mechanically locks the axle shafts together so both have equal power available to them. You wouldn't want to lock your differential on dry pavement and then try to make a tight turn. I'm sure there are others out there who are more mechanically articulate than I and can explain this better.
/ definition of 4wd? #6
I only said what Popular Mechanics said in an article a while back. I tend to believe it, for I know if you are on ice or snow, and you give a little too much gas, one tire and one tire only will spin till it bites in. And they said with awd they would both spin, not havn't one, I really wouldn't know. I have always got around just fine, in snow and ice, with just 2wd and that in the hills, so I'll most likely never find out.
/ definition of 4wd? #7
Hosejockey is correct in his explanation. 4 wheel drive can be shifted in and out while all wheel drive is in gear all the time. Some early model Scouts had single speed transfer cases but were not all wheel drive.
Eugene
/ definition of 4wd? #8
Now if I understand this correctly, a genuine All-wheel-drive, like the Audi Quattro, will do just fine if even one wheel has traction. Any one. That's been my experience driving one. Perhaps I'm just saying what others have said in different words?
/ definition of 4wd? #9
Re: definition of 4wd? *DELETED*
Post deleted by saw_dust
here you go, just dont drool.
/ definition of 4wd? #11
Looks a lot like the F215 I just sold. Are you sure the model number is FF205? Nice tractor by the way!
/ definition of 4wd? #13
That may be true, but not because it is "All Wheel Drive". The Audi must have some type of traction control or limited slip differentials in order to still move when only one wheel has traction.
/ definition of 4wd? #14
I would agree with most of that but change the terminology sligtly. To my thinking if a system is "Full time 4wd" then, as the name implies, there is no option of two wheel drive. I would call your option number 2 "Part time 4wd with automatic engagement" and option 3 would be "Full time 4wd". With the trucks I am familiar with a single stick part-time transfer case would have 4 options: 4 low, neutral, 2 high, and 4 high. The full-time 'case would offer low lock, neutral, high, and high lock. Low and high lock positions lock up the center differential in the transfer case, making it just like part-time 4wd, where the high position leaves the differential unlocked but the vehicle is still in four wheel drive.
Dave, Yep it is FF205. I got it in a direct shipment that a group of guys did here in Md. I came out pretty sweet at 1,500 bucks!!!! Just kidding guys and dealers. It is a good machine and I got lucky. Could have been a dog that was sight unseen. By the way did the F215 have any ROPS attached or did you add one? The FF205 is 20 hp at the PTO.
/ definition of 4wd? #16
Most 'all wheel drive' cars have a viscous (sp?) coupling which literally gets less viscous when the primary drive axle begins to spin. In most cases these vehicles are front wheel drive with the back powering only when needed. The differentials on these vehicles are definately 'open' with some limited slip functionality. What is interesting is some SUVs have a 'full-time/part time' system like my jeep. You can run 2wd, 4 fulltime (any pavement surface) 4 part time, or 4 low. The latter 2 settings lock the front differential, so slippery surface only. It is the best system for all uses. My wife's bravada, on the other hand, has no levers or knobs - automatic all wheel drive via the viscous coupling.
/ definition of 4wd? #17
All I can say about Quattro is that it's awesome to drive. I routinely have fun taking off from red lights and leaving 4wd trucks sitting there spinning. It's full time power to all four wheels.. until a wheel loses traction; then the power distribution shifts to the wheels which still have some traction.
Here's a brief blurb about how Quattro works that I found on
<A target="_blank" HREF=http://www.audiworld.com/news/00/geneva/quattro.shtml>http://www.audiworld.com/news/00/geneva/quattro.shtml</A>
Quote:
In the Audi quattro all four wheels are driven permanently. The advantage: in the ideal case each wheel needs no more than half the propulsive power required in a conventional single-axle driveline. Because the total force transmitted by each wheel - the aggregate of propulsive and lateral locating force - is limited, an Audi quattro can transfer a correspondingly greater lateral locating force to the road surface: a necessity for guaranteeing excellent cornering stability and outstanding straight-line running on both wet and dry surfaces.
Of course, an Audi quattro is particularly capable of demonstrating its traction advantage on wet roads, gravel and snow, on slippery surfaces or on partially iced roads. Conventional cars fitted with purely electronic control systems can also prevent the driven wheels from spinning. However, this method works only be reducing the propulsive force.
Not so in the Audi quattro, where the self-locking Torsen centre differential ensures that the engine's power is distributed uniformly to front and rear wheels. Any sudden differences in speed - for example if only the front axle hits a patch of black ice - sees the system responding like lightning: up to 75 percent of torque is then redirected to the wheels turning more slowly - in this case, the rear wheels. Torsen is a purely mechanical system.
I gather it also does this not only front to rear but side to side.. you pay a price in extra weight for all the differentials, so they add a turbo and some nice stuff for added ooomph.. but I can still get over 30mpg on the highway. I can't say enough about how good this system is.. and I've tried the ones like Subaru, etc. There is a noticeable lag time in those that simply isn't there with Quattro.
/ definition of 4wd? #18
Brett, no ROPS on the F215/235 etc's that I have imported. Some have canopies, but they are not ROPS. The newest Yanmar's have ROPS, but I haven't got my hands on any of them yet.
/ definition of 4wd? #19
<font color=red>SUVs have a 'full-time/part time' system
<font color=black>My Yukon XL has these options for the xfercase, and are electronically actuated.. no gear shift.
2wd, 4 low, 4 high, and 4wautomatic.. which is explained in the book as " engages when needed based on tire slippage', etc.
Soundguy
John Deere 4520 (A60462)
John Deere 4520...
7071CFL (A59228)
7071CFL (A59228)
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A59228)
2024 AGT LRT23...
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
