Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758?
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #31
Humm, interesting, no numbers, just green and red.
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #32
I finally remembered to do this.
Here is where my X750 temp gauge sits, doesn't move for anything,
not once in five years has it gotten any higher than this, mowing hours on end in 90+ weather.
Is this what the rest of you are seeing?
Yep, that is the same place on the gauge as ours runs too.
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #33
06-28-19 John Deere.jpgOn the 2019 dash for the 700 Signature Series, this is what they look like.
3 notches showing is the hottest it has ever been, I know, not many hours.
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #34
new dash, have to admit not all that easy to read, kind of like the old style better for viewing, but I'm sure this
shows more data points, alarming, idiot lights. Oh to have six nice round gauges in front of us...:rolleyes:
please note the little hole above your steering wheel. After five years enough dirt and crud fell in that hole and that steering wheel tilt mechanism
to totally lock mine up. Had to get dealer to take it apart, clean it, worked fine.
I bought a spare mower belt just to have, not cheap, but oem at 600+ hours still going fine.
Going to wait to see how long it lasts or until it starts to come apart.
I am going to replace the rollers on the deck this weekend, left side ones have flattened a little.
They were 8 bucks apiece or something reasonable, in a nice green box too.
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #35
It is the fine dry debris that most quickly clogs the radiator and extra cooler. I've applied extra sealing around any minor openings, but in the end it is simple clogging. The temp gauge climbs and then the PTO cuts off (thermo switch I am told) and then if not immediately cooled down, the engine will shut down. This is again is our 754. And yes, we think it is terrific other than shutting down regularly while mowing dry grasses.
Really frustrated.
Haasman
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #36
Haasman
Don't know the history of your X754, and wonder if water has been used to try to clean the radiator fins. If so, I'd suspect there is mud caked in there and restricting air flow.
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #37
beentere- I was thinking that a good project for today. I have some mowing to do so I'll do that first. Good suggestion. I'll report back whether it makes any difference.
Haasman
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #38
Sorry to report that with dry, light grass(es) swirling around the tractor still ends up on the radiator. First PTO thermal cut-off comes on (no mower) and then at even high temps the motor will stop.
I have no idea what to do at this point. Has done this since the first day. I have had John Deere dealer reps out multiple times. Had the John Deere District Service Rep come out and he replaced the engine fan. Still the same.
We really like this tractor and mower. One of Deere's best, except for the overheating problem.
Haasman
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #39
can only guess you have a coolant blockage somewhere or clogged radiator. All of which JD techs should have picked up on.
Possibly a bad waterpump? Bad radiator cap?
Mine continues to operate flawlessly at 730 hours; wish yours did
I think you have a legitimate reason to ask JD Corporate to give you a replacement mower
   / Deere site reviews indicate the X754 has overheating issues. Why not X750 or X758? #40
Talked with our RDO Tech support person. Found a bulletin retarding the overheating issue.
Complaint or Symptom :
Engine overheats and/or PTO shuts off.
Problem or Situation :
Instrument cluster may be reading incorrect temperature from coolant temperature sensor.
Solution :
NOTE: This solution is NOT applicable to X7 machines above S/N 040000 OR X950R machines above S/N 030000.
FOR DIESEL ENGINES:
Order part AM146977
To Install:
1. Cut zip tie used on engine coolant temperature sensor wiring
2. Plug male end of jumper wire into harness
3. Plug female end of jumper wire into engine coolant temp sensor on engine
4. Zip tie harness (3 locations) as shown in
FOR GASOLINE ENGINES:
Order AM147229
To Install:
4. Zip tie harness as shown in
Additional Information :
This added resistor will not exceed Engine Manufacturer’s temperature specification.
Also refer to DTAC solution 110474.
X734, X724, X758, X748, X749, X738, X739, X728, X729, X950R, X750, X740, X730, X720, X754, X710, X744, X700
Will order the part, install and report back.
Haasman
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
2014 CATERPILLAR 349FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
2011 TIGERCAT 234 KNUCKLE BOOM LOADER (A51242)
2011 TIGERCAT 234...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
