- Joined
- Sep 6, 2011
- Messages
- 15,057
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
So, I was making a tight turn with my new-to-me 855 on asphalt, in 2wd. The machine started to buck a little, as if it was in 4wd, or had some issue with a binding rear. I thought I could hear the rear tires slipping a little in the process. Machine has a model 52 FEL, but there was nothing in the bucket at the time.
I've spent several days at the controls of a Deere 750 with FEL, but other than that, I'm all new to Deere CUT's. So, there are several obvious questions:
1. Is this normal for an 855?
2. Any possibility the diff lock is dragging? Is this a locking pin or a friction disc type setup?
3. Any possibility the machine is still in 4wd when the lever is set to 2wd? How to check?
4. Is my rear (or front) diff messed up?
Thanks, guys!
Thanks, guys!
