CK20 clutch
/ CK20 clutch #1
corner bye
Kioti CK20
hey all, I have a 2004 ck 20 with 500hrs. I'm the 3rd owner and the machine was used for snow clearing with the FEL. I installed a rear mounted snow blower and love it. I was having a starting issue and resolved it with a starter rebuild and a new battery cable to the starter. I don't think the PTO was used much, and when snow blowing, heavy, wet deep snow it was working pretty hard and I was snow blowing for several hours. Any way I think it took a toll on my clutch. In the process of trouble shooting the starting issue I found that the starter was dragging while cranking and when running the RPM drops slightly when the clutch is engaged and it also squeaks a little, like a dry bearing. When shutting down there is also a squeak. I believe I'm on the cusp of a clutch change. ugg. Any thoughts would be appreciated. Thanks in advance
/ CK20 clutch #2
Could be the throw-out bearing. Most likely the culprit if the squeaking occurs when you have the clutch lever pushed in with your foot.
A burnt out clutch would smell like hot brakes. Does the clutch slip? Engine revs up but speed doesn’t increase?
/ CK20 clutch
I think the clutch is good, no slipping or smell. The squeak/chirp on shut down is puzzling. there is also a bumpy feel when lightly pressing the clutch peddle, maybe the pressure plate. The throw out bearing is definitely gone. I guess I'll know more on the tear down.
/ CK20 clutch #4
With all the work required to crack it open, you should just plan on replacing both the throw out and the clutch plates. If the pressure plate/fly wheel surface is marred, then it will need resurfacing, but you will not know for sure until you can actually take a look at it.
Also, is there a hydraulic slave on the clutch linkage at the transmission? Is there is one and there is leaking fluid it could be that it is not engaging fully. I am unfamiliar with how/if Kioti use slave cylinders on manual transmissions????
/ CK20 clutch
It doesn't feel like a slave cylinder setup, But I will be sure to check that when I get into it. I'm just lining up my ducks so that I will be as prepared as I can be when I get at it. Hope to start this weekend. thanks for the heads up
/ CK20 clutch
Update, as it turns out the clutch, pressure plate and throw-out bearing are in decant shape. The fingers on the pressure plate are a little wore. The problem is in the 2 of the lower bolts that connect the motor interface plate were loose. When I removed the flywheel it was clear. the heads of two of the bolts were wore in half, hence the squealing and stalling.
When I drained the hydraulic fluid there was what appeared to be a snap ring stuck to the drain plug magnet. That's another problem I'm going to have to deal with.
/ CK20 clutch #7
Have any pix you can post?
I have not been inside a CK20, but I did buy and set up a new one back in 2006 for a friend (RIP). He let employees use it, so it got trashed. When it stopped working, I tried to buy it back. No luck.
I think the CK20 has a single-plate, dry, mechanically-operated clutch (not hydraulic). Correct me if I am wrong.
/ CK20 clutch
Bottom couple of bolts ground down
/ CK20 clutch #9
I wonder what caused those 2 lower bolts to back out and hit the flywheel...
Do any of the other similar bolts seem under-torqued?
As for the mystery snap ring, it may make sense to pull the three point cylinder cover and look at the trans gears and shafts. A lot of work, I know, but you can't have a gear going places it should not.
/ CK20 clutch
There were 3 bolts loose total. Shouldn't those bolts have loctite on them? I'm going to keep researching the snap ring issue. One major tear down at a time.
/ CK20 clutch #11
When you cracked the engine from the trans did it look like anyone had been in there before you??.......or was the problem a factory issue from manufacture?
With only 500hours?? I am guessing this was a factory QC mess-up......unless it was opened after for some reason.
Thanks for the pics.
/ CK20 clutch
There was no tell tale signs of a previous disassemble but you never know.
/ CK20 clutch #13
Here is some reading on that issue with other older TYM/Kioti/Daedong tractors. I'm about to have to go through the same thing on my 2001 Mahindra 3510. No issues yet, but I noticed flex by the FEL and can see slight separation behind oil pan and eng/trans plate.
/ CK20 clutch #14
Glad you got it fixed, good thing you caught it before the casting got broken from the sideways stresses.
/ CK20 clutch
That's an interesting read, thanks for the post
/ CK20 clutch
Update. As it turns out all of the interface plate bolts were not tight and the main bearing cover bolts were loose as well and one was broken, either twisted or sheared off. Picture to follow.
/ CK20 clutch
Picture of broken main bearing cover bolt
/ CK20 clutch #18
Sure looks like the assembler zipped all the bolts on with an impact driver and did not come back to torque them properly. Not usually factory behavior.
/ CK20 clutch #20
It is a dam good thing you are handy and have the tools/patience.
Were you able to find all the bits of metal?
Main bearing still good/free of metal bits?
