Deere 5520 transmission problems
/ Deere 5520 transmission problems #1
bmcheek680
fleetwood nc
970 case 4440 john deere 4030 john deere 180 allis chalmers wc allis chalmers A john deere Farmall H 31 massey furguson
I'm working on a John Deere 5520 and the transmission is slipping. I thought that it could be the filter clogged so I changed it and the fluid and that did not help it. Could the hydraulic pump be out? On my 4030 John Deere the transmission pump went out but I lost all hydraulics and on this 5520 everything works great except the transmission. Anyone had this problem?? Thanks for the help
/ Deere 5520 transmission problems #2
You did not say what transmission or how many hours, but have you adjusted the clutch? If there is not the correct free play it will slip. I have included a URL to the operators manual on how to do this.
Lets hope it is just this and not the clutch going.
http://manuals.deere.com/omview/OMRE199128_19/?tM=FR
I have not yet tried adjusting it yet but I will do that first thing in the morning. Thanks I appreciate the help.
/ Deere 5520 transmission problems #5
5520's don't have a true Powershift trans. It could have a PowrReverser though.
its got a syncshuttle
/ Deere 5520 transmission problems #8
Only thing that can be slipping on a syncshuttle is the traction clutch. You need to read JD5210's link
thanks for the help. Its fixed now. the problem was the clutch pedal adjustment was to tight.
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
2012 Toyota Camry Sedan (A64557)
2012 Toyota Camry...
GEHL RSB-34 GEN:3 TELESCOPIC FORKLIFT (A63276)
GEHL RSB-34 GEN:3...
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
