Deere 455
   / Deere 455 #1
BrisMatt
Australia
JD 455
I have a deere 455 with no serial plates on it, its a very rough looking machine. I need to replace the ignition module on this machine and have read that I first need to know the serial number of the machine. What would happen if I bought a module that suits a different serial number machine? Would it still work? The ignition module I have is badly weathered and is no longer engaging the mid PTO
Thanks
Matt
   / Deere 455 #2
Hi Matt. I,ve got a 455 as well, and from what I have learned about mine, the mid pto is engaged by the pulling up on the switch on the left of the dash, and a coil that is located at the back of the tractor. I have had to replace that coil once to repair my mid pto engagement. As far as I know, that circuit does not run thru the ignition module. Are you handy with a test light ? Try and get a copy of the wiring diagram and trace thru that. Did the mid pto ever work since you bought the tractor ?
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
Trailmobile Van Trailer (A61306)
Trailmobile Van...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
2019 CATERPILLAR 336 EXCAVATOR (A60429)
2019 CATERPILLAR...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
