deere 445 runs rough
/ deere 445 runs rough #1
tonyd6383
john deere 445
hello i just bought 98 john deere 445 it was not runnig whn i bought it i just got it to run but its rough i clean out the throtle body and cleaned the fuel injector ,fresh gas and plugs any thing else i can try thanks
/ deere 445 runs rough #2
:welcome:
No good ideas. Have you checked the compression? Checked/replaced the fuel filter?
hello yes i have also check the fuel presure and that was fine , i talked to a mecanic today and he said if the temp gage is not working that could be 1 problem ,because the temp sendind unit works with the manifold air sensor . witch both parts will set the right fuel and air. i called j d and its over 300 for the parts . iam willing to try it
/ deere 445 runs rough #4
Which parts are you going to replace?
iam going to replace the temp sending unit ant the manifold air sensor
/ deere 445 runs rough #7
have you checked fuel injection wiring harness? They tend to get brittle, brake, fragile and will intermitt signal to injectors!
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
Sakai SW354 (A60462)
2018 VOLVO VNL670 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2018 VOLVO VNL670...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
