deere 445 runs rough
/ deere 445 runs rough #1
tonyd6383
john deere 445
hello i just bought 98 john deere 445 it was not runnig whn i bought it i just got it to run but its rough i clean out the throtle body and cleaned the fuel injector ,fresh gas and plugs any thing else i can try thanks
/ deere 445 runs rough #2
:welcome:
No good ideas. Have you checked the compression? Checked/replaced the fuel filter?
hello yes i have also check the fuel presure and that was fine , i talked to a mecanic today and he said if the temp gage is not working that could be 1 problem ,because the temp sendind unit works with the manifold air sensor . witch both parts will set the right fuel and air. i called j d and its over 300 for the parts . iam willing to try it
/ deere 445 runs rough #4
Which parts are you going to replace?
iam going to replace the temp sending unit ant the manifold air sensor
/ deere 445 runs rough #7
have you checked fuel injection wiring harness? They tend to get brittle, brake, fragile and will intermitt signal to injectors!
1984 Cheetah Chassis Corp 53ft. 32 Ton T/A Container Chassis Trailer (A61568)
1984 Cheetah...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
Patterson water pump (A59230)
Patterson water...
207271 (A52708)
207271 (A52708)
KUBOTA KX057-4 EXCAVATOR (A62129)
KUBOTA KX057-4...
