Deere 210 Idler pully problem
/ Deere 210 Idler pully problem #1
wolfden793
Lyndonville Vermont
Deere LX 266, John Deere Gator TX, Kubota B7500, Takeuchi TB016
Hello,
I'm new to the site and need some assistance with a problem with my John Deere 210 (early serial) that I have been restoring from the ground up and when I start the engine, the transmission idler pulley won't turn when bolt is tight and the belt (new) starts to smoke. If not tightened, it rattles, but doesn't smoke. I'm guessing a tension issue or adjustment? If you remove the pulley, it spins fine. Any help would be appreciated!
/ Deere 210 Idler pully problem #2
Welcome to the TBN. Is it possible that the offset is flipped the wrong way and the pulley is drawn into the bracket or?
Hi Tom,
Thanks for the welcome. I did consider this, but when I took it apart to restore, I took alot of pictures, but neglected to take one of the pulley to see which side the offset it on. Deere parts book and service manuals I have don't give a clear pic from an angle that would tell me. If you or anyone knows, that may solve the problem. Thanks again for your time!
Jim
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
JOHN DEERE R4023 SELF-PROPELLED SPRAYER (A64277)
JOHN DEERE R4023...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Bobcat NB160 (A64127)
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
