Dedicated blade sharpener?
/ Dedicated blade sharpener? #1
Mike_S
South of Kansas City
JD4400HST
Although I have used my bench grinder, hand grinder, files and have found my stationary 48 inch belt sander to do the best job of sharpening the blades for my mower deck, I am interested in a commercial dedicated mower blade sharpener. Does anyone know of any dedicated blade sharpeners for mower blades? Mike S.
/ Dedicated blade sharpener? #2
Mike, I don't know where you could get one or if such a thing even exists, but I have often dreamed of a big (say 14 in dia) wet wheel that would sharpen my blades and not heat them up and ruin the temper.
/ Dedicated blade sharpener? #3
Mike, take a look at www.lawnsite.com. Check under the commercial lawn care section. I'm sure you will find info on a sharpener there.Good luck.
/ Dedicated blade sharpener? #4
I just looked in my Maple GRove catalog. They have one.
Maple Grove Distributing
10998 E State Rd 18
Galveston, IN 46932
1-800-356-0331 order line
Order a catalog. They have very decent prices.
Your response brings up another question--with whatever the Rockwell hardness of JD blades that I use, how hot can I get them without affecting the temper of the steel? For example, some tool steel does not loose its temper until it reaches 1100 degrees which means that it can even get red before it loses its temper, while another type of tool steel may loose its temper at 850 degrees, which means it an get black when sharpening, but not cherry red. Good answers bring more questions. Mike S.
/ Dedicated blade sharpener? #6
Mike, I am not very well versed in tool hardness. Often, when I am done sharpening things, the edge takes on a permanent 'blue' color. This always seems to happen if I get the blade very hot from agressive grinding. Maybe I need some schooling in this area.
/ Dedicated blade sharpener? #7
This has been discussed on Lawnsite.com. Any of the landscaper supply houses have them, but a good one that does a proper job is VERY expensive. I don't recall how much, but around $1,000 comes to mind. The general opinion there is that the cheaper ones don't do the job right and you are better off doing them like you are now than buying a cheap one.
/ Dedicated blade sharpener? #8
By way of introduction, I make hunting knives. If you see any color when grinding the blade, you have softened the blade. Those blades shouldn't see anything darker than a dark straw color or they are getting too soft. They will still be usable, but won't hold an edge as long. When grinding heat treated steel, I keep a 5 gallon bucket of water to dunk the blade in after every pass on the grinder. A belt grinder
doesn't heat up the steel near as bad as the stone ones.
/ Dedicated blade sharpener? #9
When you say a belt grinder, are you talking about the belt sander that I use to plane wooden doors. Can I use this tool to sharpen mower blades? I can't get quite the control that I desire using a bench grinder or angle grinder.
/ Dedicated blade sharpener? #10
I have one that will fit the bill. It is about 100 years old and you sit on it and pedal it. The only thing that overheats is the operator.
/ Dedicated blade sharpener? #12
What I use is my 2 x 72 inch knifemaking belt grinder. The cost is too high for just this, $1000 - $2000. Surely a belt sander would do it. Use about 120 - 280 grit belts. This doesn't have to be brain surgery. The steel involved is probably 1060 - 1080 plain carbon steel or 5160 spring steel like that found in the leaf springs of your pickup. If you take these simple steels to 450 degrees F, you just have just about tempered all the hardness from them. I can't imagine they are treated any harder than 48 - 50 RC, anyway. This about the hardness of hammers, anvils, and Shrade pocket knives. No way you would want one to shatter on impact with a rock or something. No one will return one for not holding an edge, but they will sure complain if one breaks. Not to mention the liability. If they aren't too dull, I just put my finish mower blades in the vise and use a file. I like a small flat or round at the very edge. Used to sharpen them like a pocket knife. Took the blades off an old bush hog once. Then went to the angle grinder. Unhook the top link of the 3ph, then use a comealong to hoist the backend of the bush hog from the truss of a Morton shed. Haven't found balance to be critical in my limited experience. Oh well, this is getting long. Enjoy the forums a lot.
Bill Tester
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2008 VOLVO VNM 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2008 VOLVO VNM 6X4...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
