Deck weight capacity
/ Deck weight capacity #1
rd_macgregor
Prince Edward Island, Canada
Kioti DK45SC, Kubota B2650
I'm not sure is this is the right place to ask this, but here goes...
I have been looking for a truck or trailer deck (or "flat rack" container) to use to replace an old wooded bridge.
I recently saw an 8' X 18' truck flatbed for sale that might do if I first cut off the cab protection (vertical) part of the deck.
My question is, how do I tell if this is structurally strong enough for my use, if I support it near the ends with, say, a 16' span? I want to be able to drive my tractor, with implements across it, maybe a loaded log trailer, dump truck or other heavy equipment. I figure I'd need maybe a 20,000 lb capacity, more or less, just to be on the safe side.
Any suggestions?
Thanks,
BOB
/ Deck weight capacity #2
Measure the main frame members of the bed and you can calculate their bearing capabilities, assuming you can also properly guess the type of steel used.
/ Deck weight capacity #3
I would not think a truck flatbed would be strong enough. I had a 25,000# GN trailer and it had 10" I beams or maybe 12", I can not remember. You would need something this strong atleast.
For only 16' I would get some rough saw white oak or even some used I beams and place them on concrete peers and go from there.
Chris
/ Deck weight capacity #4
Not a bad idea if it holds the load over time, a pre-built bridge ... since it doesn't matter how bad the tires or axles are, I'd think you could come out for less $$. I'm interested to see what you end up with as I have lots of ravines and will need to span a few areas myself in the future.
I haven't actually looked at this yet or taken any measurements, but I should have included this link (note that the hay cart underneath isn't part of the truck bed:
18ft flatbed - Charlottetown Farming Equipment For Sale - Kijiji Charlottetown Canada.
I did a lot of research on shipping containers and determined that what I really wanted for my replacement bridge was a "flat rack" container. These have the same strength as a regular container but lack the superstructure (they just have vertical ends (sometimes collapsible). Sadly, they are not as readily available (I found a couple of 40-footers in New Brunswick for $3k apiece, but didn't want/need 40' and couldn't figure out how to get them shipped here... plus, I didn't want to pay that much!
That's why I started looking for alternative, prefab options, like truck/trailer decks.
If I find one that is strong enough, my plan was to have a local contractor pile-drive pairs of I-beam columns on each side of the stream crossing and weld the bridge to I-beams welded across these supports (an inverted "U" under each end of the bridge).
For all this trouble, you'd think a big culvert would do the job a lot easier. The problem is that the local environment dept. folks get a lot more heavily involved if you start mucking around in the stream bed.
BOB
/ Deck weight capacity #6
Here is the picture
Based on the ratio of outside channel height to tire height I believe the outside channel or tubing is 8" and the inner support members are 12".
It looks plenty strong to me.
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59912)
2020 ATLAS 2 POST...
2017 Ford Box Truck (A62613)
2017 Ford Box...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
