Deck treatment
/ Deck treatment #21
I've been using used motor oil/diesel fuel "cocktail" on traile decks, hay racks, fences and barns for near 40 years. I've got acouple hay racks that are almost that old. They've held up well. Motor oil repells water. SOME waterproofings and/or paints SEAL the surface but can trap water inside the wood if it enters through a crack or scraped area. Oil soaks in and has "depth" to its protection. After a few days to soak in, I've never had an issue with oil "tracking" on my shoes. Also, it raises the grain on many woods, actually giving MORE traction. I use a long nap paint roller. Put a sheet of plastic down under the trailer to catch drips until theoil is absorbed fully. (Soundguy gets rather irate if you don't ;) )
/ Deck treatment #22
My gooseneck is starting to show some weather cracks in the boards.
i've been wondering about useing the black fence paint that is pretty well much diluted roofing tar. would think it would add traction.:confused:
/ Deck treatment #23
This may be a little off topic, but it relates to the traction comments...
I need to get some of that traction tape or something on the metal frame at the back of my wooden deck. If I can get enough of a running start to get my wheels onto the wood, I can load anything on the tilt trailer. If not, my wheels just slip on the metal.
I wonder if I could just turn the heat way up on my stick welder and hold it back as far as possible. Basically just put a bunch of spatter down without a bead.
In the mean time, I'm just looking for a good time a place to paint my deck with oil and diesel.
Anyone have any ideas for adding pigment to the mix to make it even darker?
/ Deck treatment #24
I just added a coating to a trailer Friday. I looked at the wood getting checked and saw a lonely paint roller and it clicked -- Hey, that one needs a coat! By happy chance, the bush broom handle fits the paint roller. The 12 qt oil pan is more than big enough for the roller. It took about 3-4 gallons to do the 8-18' trailer. I gave it 3 light but complete coats. There are still areas that are showing light. It might be that I used 1/2 engine oil and 1/2 hydraulic fluid with just a 2qt fuel filters worth of diesel. Traction on the deck is good as ever, water beads up with no "rainbow" and the smell is nearly gone. Unless you sniff at it. It was pretty cloudy all weekend. I imagine that if it was hot and sunny, the smell would be gone pretty quick.
If you want it dark, get some oil based stain and add it to the mix. Or go to a paint store and get some black dry pigment powder. Seems like a lot of work though.
If you want to add traction, use a truck bed coating on the metal. It will last a long time and if you do it yourself is pretty cheap at about 20-25 a qt at the big box hardware and farm stores. Your idea probably won't work as the splatter will probably get removed by the tires spinning pretty quick.
/ Deck treatment #25
I was afraid of that.
After I posted, I thought of just putting down some beads in parallel to each other. It would be more permanent than the Rhino liner. I think it would do the trick too.
One of these days when I'm bored and ambitious, I may try it. The trailer can't get much uglier than it is, so I'm not too worried about the appearance.
/ Deck treatment #26
If you don't care how pretty it is, why not weld on 12" long 3/4" rebar on 8" centers to make a set of metal ladders? That would work and be about as permanent as it gets.
/ Deck treatment #27
So after a weekend I can admit that the dirty soot oil and diesel combo is a fantastic deck stain. The color has mellowed into a mahogany with just enough brown showing through from the wood to make it a classy deal.
So the wife looks at it. Touches it, dry on her finger, and tells me.... so how much of this can you mix up? She wants to paint a whole freaking 200 foot long 5-6 foot tall board fence with it. It passes the girl test. Trouble is that I will need maybe 10-15 gallons.
One important thing to note though is that the color of the finished product seems very depenent on the "dirtiness" of the oil. You can't use new oil and then switch to used black oil or hydro fluid since the color will be different.
I'll shoot to change the powerstroke's oil here soon and that'll get me like 5 gallons of the oil.
/ Deck treatment #28
I only need to "texture" the first 4 inches. The rest is all wood. Once I can get a wheel on the wood, I don't have any traction problems.
This is an old trailer and years of use has polished the metal up pretty slick.
/ Deck treatment #29
" It passes the girl test. Trouble is that I will need maybe 10-15 gallons."
I've got a 55 gallon drum just about full ready for the trip to the oil recycle plant. If you want it come and get it !:)
/ Deck treatment #30
You could take oil from various sources and mix it all together to get a single color for the whole job.
/ Deck treatment #31
You guys are discussing color matching used oil.....
seriously?
jb
/ Deck treatment #32
Guy stuff for sure...
Sounds fair to me and besides, I've found myself discussing worse, sillier things in the past ... some stuff I can't believe.
This is interesting and good John.:)
/ Deck treatment #33
I dunno..... next we'll start color co-ordinating the grease stains on our clothes with the color of our socks!
jb
/ Deck treatment #34
seriously?
jb
Now give us some slack. The color matching didn't start until Highbeam mentioned the "girl test".
/ Deck treatment #35
Slack? Here? No way, buddy!
By the way, if you are wearing any red accent clothing (socks, scarf, belt, ascot, etc), Mystic full synthetic grease is a nice shade of red and should work well with your ensemble. Some are a green color and will clash, so be sure to check what your wearing so it goes with your grease! ;)
jb
/ Deck treatment #36
jb
I was laughing so hard about this thread tonight as I was putting parts of my Massey Ferguson SCUT back together using red RTV. It's almost a perfect match to Massey Red.
/ Deck treatment #37
LOL, yeah me too.
I was thinking back to when I switched to that red marine grease for the same reason. Especially when it squished out a little. It made a nice accent of red between black to match my Kama theme. But of course that's technical stuff and WAY different than color coordinating dressing like chicks do.:)
/ Deck treatment #38
LOL, yeah me too.
I've been told that if you tell a woman her socks don't match she'll look at her shirt. If you tell a man his socks don't match he simply looks at both socks.
/ Deck treatment #39
I like the red grease but when it smears on your arm its always black anyways.
There's a time for proper colors, I mean cripes, your truck is the same color on all panels isn't it? Your hosue the same color all around. With winter coming I won't be able to collect and color match sufficient engine oil for the fence job so I'll have to risk a goofy looking job.
I cleaned up the slop from the trailer deck last night. You know, the oil that got onto the metal and didn't soak in. I found that lots of little fruit fly looking bugs had died on the oil soaked deck. Good for traction I suppose. The smell of diesel/oil is now gone and the deck is not oily to the touch.
Excellent suggestion on this deck treatment. I'll never purchase deck stain again for the trailers.
/ Deck treatment #40
But does your trailer deck stain match your socks?
Couldn't resist!
jb
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2017 Nissan Sentra SR Sedan (A61574)
2017 Nissan Sentra...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2023 Case TV450B (A62177)
2023 Case TV450B...
