Decided on my first tractor
/ Decided on my first tractor #21
Trying to get info on upper the pressure.
Wish I had someone close to me that knows these Tractors and what to do..., I'm a little nervous !
My previous Tractor, a Yanmar, had two pump
BRMyers,
Seat Belts are a good thing when applied properly BUT when you are in a tipping situation the seat belt gets in the way, so when I am working a hill side or slope, I do not wear the belt... IF the Tractor decides I have over extended the balance point then I want to be able to jump off !
Won't go into RIGHT or WRONG !
Hopefully you will never need to find out, but that ROPS system is there to protect you during that rollover and the seatbelt keeps you in that sweet zone.
/ Decided on my first tractor #22
Nice looking tractor. Here's wishing you many happy hours of service from it!:tractor:
/ Decided on my first tractor #23
Not Strong Enough... why I say that is because I can't drive up my driveway with a full front bucket without stopping and putting the Tractor in Low Range; yes in Low Range it does a decent job !
Lifting, I went by the specs, more than my last Tractor, but to me I feel I have to struggle to get it to pick up the same things, I don't have picture of actual measurements so I can't say absolute, more guessing on the feel.
I was just moving some of Metal shelving with the FEL, strapped it in, backed up, when I went forward and started to roll the bucket inward and the the Tractor slowed, I think the pump isn't large enough to handle the added hydraulic load of two functions at once.
The back hoe, again going by what I remember, the feel is that the Mahindra doesn't dig as well as my older, smaller, Yanmar.
And although not a power thing, I wish this Max28 had a shift on the fly Transmissions; the Mahindra has to be stopped before moving the Hi/Low Lever.
I have checked the Fluid Levels and I have raised the RPM Level while doing projects, so I don't know what else to do but that is a story for another thread.
Ltr
3 range HST? . . . if not that could be your problem. never mind I did look it up 2 range, there is the problem.
2006 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2006 Hypac C530AH...
2018 CATERPILLAR D11T HIGH TRACK CRAWLER DOZER (A65056)
2018 CATERPILLAR...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65054)
2023 WALLACE-THE...
KUBOTA MOTOR (INOPERABLE) (A68842)
KUBOTA MOTOR...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
