dead cylinder
   / dead cylinder #1
irl3r
JD 870
I’ve got a JD 790 with a 3tne82a engine with only 539 hours that has a cylinder not working. the tractor started running poorly. so after checking for obvious issues i tried cracking the injector lines one at a time . on cylinder 3 it made no difference in the way the engine ran. i swapped injectors and the problem did not follow the injector . my next step is a compression test. has anyone experienced this issue.
   / dead cylinder #2
Stuck valve?
   / dead cylinder #3
irl3r
Welcome to TBN
When you cracked the lines, did you get fuel at each one?
Do you have the service tech manual?
   / dead cylinder
yes , loosening cylinders 1and2 fuel feed lines the engine nearly cuts off
   / dead cylinder
yes i have manual .
175 psi in #3 cylinder cranking engine over
   / dead cylinder #7
175 PSI seems low for a diesel, did you check the other cylinders for a comparison?
2022 John Deere Z930M (A57148)
2022 John Deere...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2018 RoGator 1100C (A56438)
2018 RoGator 1100C...
2018 Trail King Lowboy (A56438)
2018 Trail King...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
