dead cylinder
   / dead cylinder #1
irl3r
JD 870
I’ve got a JD 790 with a 3tne82a engine with only 539 hours that has a cylinder not working. the tractor started running poorly. so after checking for obvious issues i tried cracking the injector lines one at a time . on cylinder 3 it made no difference in the way the engine ran. i swapped injectors and the problem did not follow the injector . my next step is a compression test. has anyone experienced this issue.
   / dead cylinder #2
Stuck valve?
   / dead cylinder #3
irl3r
Welcome to TBN
When you cracked the lines, did you get fuel at each one?
Do you have the service tech manual?
   / dead cylinder
yes , loosening cylinders 1and2 fuel feed lines the engine nearly cuts off
   / dead cylinder
yes i have manual .
175 psi in #3 cylinder cranking engine over
   / dead cylinder #7
175 PSI seems low for a diesel, did you check the other cylinders for a comparison?
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2018 JOHN DEERE 333G SKID STEER (A60429)
2018 JOHN DEERE...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
