dead cylinder
   / dead cylinder #1
irl3r
JD 870
I’ve got a JD 790 with a 3tne82a engine with only 539 hours that has a cylinder not working. the tractor started running poorly. so after checking for obvious issues i tried cracking the injector lines one at a time . on cylinder 3 it made no difference in the way the engine ran. i swapped injectors and the problem did not follow the injector . my next step is a compression test. has anyone experienced this issue.
   / dead cylinder #2
Stuck valve?
   / dead cylinder #3
irl3r
Welcome to TBN
When you cracked the lines, did you get fuel at each one?
Do you have the service tech manual?
   / dead cylinder
yes , loosening cylinders 1and2 fuel feed lines the engine nearly cuts off
   / dead cylinder
yes i have manual .
175 psi in #3 cylinder cranking engine over
   / dead cylinder #7
175 PSI seems low for a diesel, did you check the other cylinders for a comparison?
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
4-Wheeel Hay Rake (A56438)
4-Wheeel Hay Rake...
2020 CATERPILLAR 323 EXCAVATOR (A60429)
2020 CATERPILLAR...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
