dead cylinder
   / dead cylinder #1
irl3r
JD 870
I’ve got a JD 790 with a 3tne82a engine with only 539 hours that has a cylinder not working. the tractor started running poorly. so after checking for obvious issues i tried cracking the injector lines one at a time . on cylinder 3 it made no difference in the way the engine ran. i swapped injectors and the problem did not follow the injector . my next step is a compression test. has anyone experienced this issue.
   / dead cylinder #2
Stuck valve?
   / dead cylinder #3
irl3r
Welcome to TBN
When you cracked the lines, did you get fuel at each one?
Do you have the service tech manual?
   / dead cylinder
yes , loosening cylinders 1and2 fuel feed lines the engine nearly cuts off
   / dead cylinder
yes i have manual .
175 psi in #3 cylinder cranking engine over
   / dead cylinder #7
175 PSI seems low for a diesel, did you check the other cylinders for a comparison?
Cummins Engine (A59230)
Cummins Engine...
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
FUEL CELL (A58214)
FUEL CELL (A58214)
Chemical Containers Tank (A57148)
Chemical...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
