DC motor Control questions
/ DC motor Control questions #21
Why not try and accomplish the flows and pressures you want on the fluid side.
Restricting the flow on a centrifugal pump reduces the load since there is no flow.
A globe valve on the output would give you a reasonable throttling control. Don't use a ball valve as fine tuning it is difficult.
You can also tee off some of the output and send it back to the reservoir using a valve to control how much .
Dave M7040
I think Dave is on the right track. Does it have to be DC? Does it need to be a special pump or will a water pump work? You could do this with a normal shallow well pump with a pressure tank and a pressure switch. Just like house plumbing, a valve moderates the flow. Pump turns on and off with the pressure switch. Easy-peasey.
So I will be pumping Grape must. Was thinking about peristaltic as the pump type as yes it has to be food grade. Since I have to compress the tube I would expect to have more torque requirements. I believe if I go with this pump type that I wont be able to do it on the fluid side as it will want to push out a pre-determined amount of fluid. So high viscosity, and tube compression, hence the 5hp consideration. I'll check out the VFD more throughly tonight as an option.
'll
If I do go with FVD, can i use any sigle phase AC motor with it?
/ DC motor Control questions #25
If you can only supply single phase power to the input of the VFD check the manufacturer's specs
to make sure it will allow you to run it on single phase. You will also need to derate a single phase
input drive. You may need to get a 7.5 or 10 H.P. drive to run your 5 H.P. motor
/ DC motor Control questions #26
If the drive is not rated for single phase, it can still work with single phase input but you do have to derate.
If the drive is dual rated for both 1/3 phase (most of the smaller ones under 3hp are), you dont need to derate.
/ DC motor Control questions #27
/ DC motor Control questions #28
Can you run a single phase motor using two phases (without capacitor)?
/ DC motor Control questions #29
I don't really understand.
Are you asking if you have three phase, if you can run a single phase motor off just two legs, the answer is no.
/ DC motor Control questions #30
If you have a 3 phase system, say 208/120 volt, you can certainly run a single phase 208 volt motor off 2 of the legs.
A vfd would work pretty good for the OP, but given that he needs less than 1 hp, a DC motor and speed control from Grainger might be cheaper.
/ DC motor Control questions #31
Still don't know what you need to do.
It just so happens that I have 2 variable speed controllers (new surplus) that can drive a variety of motors, generally they are DC 90 volts.
They are brand name units that can handle (think) up to 3 hp. or so by simply changing a resistor.
As is they have 1/2 or 1/3 motors and can do, like 10 RPM thru to 1750 or so.
I have 'played' with them a bit and am impressed with the quality.
PM me with more details and we can talk.
/ DC motor Control questions #32
The capacitor generates a phase making the motor spin in certain direction so I thought that I could use one of the phases instead of capacitor.
/ DC motor Control questions #33
Still dont understand what you are trying to ask here?
What do you have? and what are you wanting to drive?
/ DC motor Control questions #34
From the original post I understand that what you are looking to build is called a "must pump." ("must" is what winemakers call crushed grapes). Googling, it seems that must pumps are pretty involved and the low-end ones are thousands of dollars. Somehow I don't think that motor speed control is the central problem.
/ DC motor Control questions #35
Single phase motors are actually two phase motors. One phase comes from the grid directly and the second is generated by the capacitor that causes phase shift. So if you remove the capacitor can you use a phase generated by the VFD electronics.? I am asking just out of curiosity.
Yes a must pump is a complicated pump. Generally speaking, I COULD run the pump from a single speed and not worry about speed control at all. The design of the rest of the pump is underway, and I'm optimistic I have something that will work, but it would be great to have it variable speed. Typically these pumps on the smaller end run a 3000$ price tag for a fraction of what I'm looking for, hence the desire to build one. Even splurging on a nice VFD and a DC motor I would come in way under cost if I can get it right. 4-9 KW seems to be a normal rating, which I believe transfers relatively closely to HP. Everything that I'm hearing here leads me to the conclusion I'm likely better off leaving the electronics to the experts, and focusing on the mechanical. So a nice sturdy DC motor and a VFD is where I think I'm landing on this one. Thanks for all the help so far.
/ DC motor Control questions #37
DC motors and VFD do work together. If you are going run a DC motor you need a DC drive. A DC motor needs a field, either permanent magnet or wound copper field. Never weaken a field unless you have feedback control as under light load the motor will run away and can fly apart. A FVD driving into a 3-phase motor works quite well. Bosh makes a nice VFD that operates on single phase and can drive a 5 HP 3-phase motor. I recently installed one on a wheel polisher. I am very familiar with the type pump you plan to use, sometimes referred to as a toothpaste pump in the trades. We ran dozens of them with both DC and AC drives, most were 2 HP or less. We used C face motors direct coupled to a right angle gearbox, ratio set to keep motor speed near 75% of base speed. Keep the speed up for best regulation and longer motor life. Pumping a liquid with solids in it be sure to use overload and over current protection to protect the motor and pump.
/ DC motor Control questions #38
No you can't do that. Two legs off of a three phase system is still single phase. You do not get 2 sine waves. They resolve into 1 sine wave. If you are familiar with vector math, and want to play around with it on paper it will make sense.
You can run a single phase motor off of 2 legs of the three phase system, but it still needs it's capacitors.
You are right that the capacitor creates a phase shift in the 2nd winding to allow the motor to start in a particular direction.
You could design a motor to run off of 2 legs and a neutral of a 3 phase WYE system, but what would be the point? You would still need 3 wires and a special custom motor. Plus it would run like a 3 cylinder engine hitting on 2 cylinders.
Your main "take away"....2 legs off of a three phase system is not "2 phase" system. It is purely a single phase system.
If you use a VFD, there is no need for a single phase motor, The VFD will generate 3 nice, symmetrical phases from a singe phase source.
You can use a DC motor and DC drive too. Just get a AC or DC motor and Drive combination that are designed to work together (obviously).
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
Kuhn FC 4000 (A64126)
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
