Dash replacement
/ Dash replacement #1
Zick
Platinum Member
WI
BX 2350
Mine's not needing replacement yet but was always curious about one thing. Does the hour meter hours transfer over or are you starting from zero again?
I also found after reading this thread 70 Series BX Dash in 60 Series? - OrangeTractorTalks - Everything Kubota that there is an updated cluster that is a different design and even comes w/ a wire adapter for different models.
I can't seem to find this bulletin they reference online.
Anyone done this yet?
/ Dash replacement #2
Unless the tractor has a computer with an internal memory driving the gauge you can probably expect a new gauge to start at zero. Make a note of your original hours when swapping gauges.
/ Dash replacement #3
Last time I needed a replacement meter it came with an adhesive label on which to write the hours on the old meter and attach it to the instrument panel. Not sure if Kubota is that way.
New/Unused Open Backing Plate (A61166)
New/Unused Open...
26120 (A56859)
26120 (A56859)
New/Unused Wolverine 78in Land Leveler (A61166)
New/Unused...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
2019 BOBCAT T870 SKID STEER (A62129)
2019 BOBCAT T870...
LandHonor LHR-MC2113 Metal Carport (A60352)
LandHonor...
