Cyclone rake
   / Cyclone rake #11
I am going into my fourth season with the XL behind a 60" ZTR:
We have lots of leaves and decent hills. I cannot imagine cleaning up without it. As is I spend six 8 hour days each season and end up with a huge pile of shredded leaves that becomes the basis for our compost.
Our lawn looks great and the product works great. A few notes:
- takes getting used to the swing driving as the hitch is a fixed 2 point hitch, on my mower this makes the drive wheels true pivots with casters at the front and under the collector, not sure how this will feel on a tractor
- even half full it is like driving a bus around the yard, get the dual wheels
- hills should only be taken up and down, not cross, I still get front wheels off the ground if not careful
- the gas tank lid has a filtered vent that clogged last year, had to special order a new one as it was not serviceable and was expensive (maybe $30)
Bottom line is I cannot speak highly enough of this product for my application and recommend if you can fit it around your property obstacles and have leaves it is a huge timesaver.
   / Cyclone rake #12
It works really well. Had it for 3 years. I have the Commander & dual wheels, which if you have any wet/soft spots, you will want. On hills, when it is almost full with grass clippings, it will "help" you down the hill. With the Kubota BX25, you will be fine pulling it up. I have an extra boot on a JD garden tractor, which will not pull it up some of my steeper hills when getting full. One thing for sure, way easier than a hand rake!
   / Cyclone rake #13
Well let me add that I too hated to spend the $$$ but it is as advertised. I have it on a 60" eXmark Lazer Z. I even went back and purchased the 30' hose attachment to clean out the flower beds. I have a lot of walnut trees and was worried about them, after 5 seasons the impeller shows no damage or wear. I now turn the leaves into compost, I usually have about 1000 bushel per year. (FINE PRODUCT)
   / Cyclone rake #14
Is anybody using a Cyclone (or similar product) on a CUT size tractor versus the L&G size? I've only seen them advertised or referenced here on TBN using the L&G tractors.
I don't see why one would not work on the CUTs like my Kubota B2620.
Cheers,
Mike
   / Cyclone rake #15
You just need the right size boot to fit the mower deck. Measure your opening and call them. I think the boot for the BX25 was like $80.
   / Cyclone rake #16
Thanks, it looks like "Texas42" has a CUT size tractor.......
I'd just need a boot for my CUT.
   / Cyclone rake
I have looked at the DR several times and think I am going to order my Cyclone rake tonight.
My reasons are
1) DR uses a longer hose and it sort of hangs out a good bit - figure shorter hose better suction, less to drag and catch on stuff
2) I like the rake with the solid hitch because I have to back up a bunch to get in some tighter spots so it will be easier
3) Love the impeller on the Cyclone as it flexes to prevent damage
4) DR uses a off brand engine - the quality maybe fine but here in rural WV I can get parts for a Briggs about anywhere, but with the DR I would always have to order anything I need
The whole idea of the tow behind is also a plus as I am going to make a hitch (2" receiver to the plate style mount the rake uses) for my Side by Sides so I can tow it and use it without the tractor if I want to. Figure cleaning out flower beds and such I really don't need the tractor and if the backhoe is on it sure will be easy to hook it to the SxS.
   / Cyclone rake #19
As stated before, I have had a Cyclone Rake for about 5 years. Great machine. I pull it with a JD 2320. Cyclone Rake has a 3PH setup as a option. I don't think it is extra $'s.
I clean up leaves on 3 1/2 acres with about 80 trees, so it gets a workout.
I don't know what I would do without it.
I usually do 3 passes, one in November, one in December, and then get the stragglers late December.
My only complaint is to dump it when it's really heavily loaded is a bear as it's heavy to lift up and the leaves are packed in. Once you get it tipped up and the leaves started to flow then it dumps ok.
   / Cyclone rake
My big debate is get the XL or the Z10. The factory deck boot is 8" so I am not too sure there is a benefit to the 10" hose on the cyclone rake? The impeller is the same on both models so I am not too sure you really gain a lot with a 10" and 2hp over the 8" hose at 8hp (as in the amount of suction). I am not sure I understand how additional HP on the same size impeller makes more suction, I would have thought it would be thought the RPMs spinning it faster is what would make more suction?
I just don't want to spend extra money for nothing.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
71050 (A49346)
71050 (A49346)
