CX2510 top lengths?
/ CX2510 top lengths? #2
I can get you the closed measurements tomorrow. I'm looking to do the same but will order it from Fit Right Hydraulics. @MtnViewRanch
/ CX2510 top lengths? #3
Closed, center eye to center eye it's right at 19 inches.
What I would consider fully open (pic) is 29 inches.
/ CX2510 top lengths? #4
Based on the info supplied, I would say either a 19 1/2"- 27 1/2" or a 20"-29".
It is actually better to get the asked for dimension of the following link and base the best possible working length off of that dimension.
/ CX2510 top lengths? #6
"The best way to do this is to have your tractor hitched up to your box blade (as an example) have the implement level with the ground front-back and side-side. Have the implement on the ground, measure the pin-pin distance."
So would this distance ideally fall right in the middle of the closed/open spread?
/ CX2510 top lengths? #7
Typically for tractors with a 7" stroke or less, centered generally works the best. For 8" and longer strokes, 1/4"- 1/2" more retraction than extension seems to work well.
/ CX2510 top lengths? #8
I should be getting my CX2510 next week. Did you pick a top link and hoses? If so, do you mind sharing what you go? Thanks!
121A (A63745)
121A (A63745)
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
Agri GPS Module (A63117)
Agri GPS Module...
JOHN DEERE 2040 TRACTOR (A63291)
JOHN DEERE 2040...
