Cutting with an angle grinder
/ Cutting with an angle grinder #11
I have had those cut off wheels come apart. I pulled 1\5 out of my thigh and found the rest 50' away.
I would not use one any thinner than necessary and go slow and steady. By all means use protective eyewear and keep the guard where it will do the most good.
It's an effective, efficient cutting tool but pretty dangerous.
/ Cutting with an angle grinder #12
...those cut off wheels come apart...
IMO...this is a good thing...if you bind the wheel (the thicker the piece being cut the easier it is to bind)...beyond the critical point the composite wheel (breaking up) absorbs a lot of the energy and eliminates a lot of the kick back where a solid blade could cause much worse injuries...
/ Cutting with an angle grinder #14
I have a 6" metabo and it's main purpose is cutting with a cutting wheel. Definitely need 2 hands not just for safety but to keep a somewhat steady cut. It works great I think. Grinding is usually reserved for one of the 4.5" grinders. I think I may get a 9" next and would not hesitate to put a cutting disc on it.
/ Cutting with an angle grinder #15
Especially on a 7" or 9" grinder, you want a guard installed when using a cutting disc. 7" used to be the only grinders available. A 5 or 6" is a lot easier to handle and control.
/ Cutting with an angle grinder #16
Cut off wheels are great. I worked for one co that would write you up for running grinding, wire, tiger discs or cutting wheels other than metabo on a metabo. They were also pretty strict about guards too. I like to pull all guards off my grinders so my wheels won't have flat spots.
/ Cutting with an angle grinder #17
"I like to pull all guards off my grinders so my wheels won't have flat spots."
What does this statement mean?
I've seen a lot of guys put a 7" disc on a 5" grinder and come very close to cutting their finger off holding the side handle. Even on a 7" grinder, it wouldn't be hard to do.
/ Cutting with an angle grinder #18
It was an attempt at humor. Wire wheels cut and buff better if you flip them ever so often. Guard will not allow it.
/ Cutting with an angle grinder #20
Would you like to see pictures of a co-workers hand that thought pulling the guards off a grinder was a good ideal too. Plenty of blood and gore since you seem to be into that sort of thing.
SWITCH HITCH HYDRAULIC HAMMER ATTACHMENT (A60736)
SWITCH HITCH...
FENCE PANELS (A58214)
iDrive TDS-2010H...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
Toro z turn (A56859)
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
