Cutting Tools
/ Cutting Tools #21
Plasma cutter hands down. Mine is currently limited to a mechanized cutter head, as its on a cnc table. im looking to get a hand held tip for it to increase its usefulness.
i routinely cut thru 1/2" and 3/4" steel. very clean edges.
/ Cutting Tools #22
/ Cutting Tools #23
I have a cutting torch, chop saw, angle grinder, I am looking for something to make long, clean cuts on larger steel, like if I was going to make a BH bucket or something. I was going to look into a plasma cutter, but trying to cut a straight line may be challenging. I like the bandsaw idea, but can you cut large pieces with a metal band saw? I've never used a metal band saw, but does it work pretty much like a wood one? The metal circular saw looks like it may work well also. If I am going to spend the money, I want something that will be very versatile.
For layout of sheet, シ inch and thicker I think either the gas torch or plasma is your best bet! If you are going to use this in a shop setting only in the future then I would go with the plasma, but if you ever want to / or have to take this unit out into the field the gas torch set is the way to go. They do not require such a long extension cord like the plasma rigs do!!:laughing:
/ Cutting Tools #24
You can not get a perfect vertical hole, so what is your angle at the bottom. For instance, if cutting a 1 in hole on the top of 3/4 or 1 in, what is the width of the hole on the bottom? I had to ream out the hole for bushings and pins.
/ Cutting Tools #25
there not absolute perfect, that is true, but if the tips are new or near new, they only need a very little deburring (usually with a dremmel tool and stone). I just cut the 1" holed in the 3/8 plate for my bucket, and it only took 20-30 seconds with the dremmel to smooth it out. If i need a 1" finish hole, i set the cnc to cut me a 0.98" hole, then i grind it to fit.
I wish i could afford a laser....but that will never happen.
Straight cuts are usually better than full circles, but id rather have to use a dremmel than a drill press.
/ Cutting Tools #27
For cutting straight-line 1/2'' thick and less I use the Evolution circular saw. It works great and doesn't leave a mess in the work area. When you are done, the pieces are clean and ready to assemble. Cost is a lot less then investing in a plasma cutter if you don't plan on doing a lot of cutting.
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
Caterpillar Specification Manuals Vol. 3 Books 1 and 2 (A63117)
Caterpillar...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
JOHN DEERE HX 14' ROTARY MOWER (A63291)
JOHN DEERE HX 14'...
