Cutting Tools
/ Cutting Tools #21
Plasma cutter hands down. Mine is currently limited to a mechanized cutter head, as its on a cnc table. im looking to get a hand held tip for it to increase its usefulness.
i routinely cut thru 1/2" and 3/4" steel. very clean edges.
/ Cutting Tools #22
/ Cutting Tools #23
I have a cutting torch, chop saw, angle grinder, I am looking for something to make long, clean cuts on larger steel, like if I was going to make a BH bucket or something. I was going to look into a plasma cutter, but trying to cut a straight line may be challenging. I like the bandsaw idea, but can you cut large pieces with a metal band saw? I've never used a metal band saw, but does it work pretty much like a wood one? The metal circular saw looks like it may work well also. If I am going to spend the money, I want something that will be very versatile.
For layout of sheet, シ inch and thicker I think either the gas torch or plasma is your best bet! If you are going to use this in a shop setting only in the future then I would go with the plasma, but if you ever want to / or have to take this unit out into the field the gas torch set is the way to go. They do not require such a long extension cord like the plasma rigs do!!:laughing:
/ Cutting Tools #24
You can not get a perfect vertical hole, so what is your angle at the bottom. For instance, if cutting a 1 in hole on the top of 3/4 or 1 in, what is the width of the hole on the bottom? I had to ream out the hole for bushings and pins.
/ Cutting Tools #25
there not absolute perfect, that is true, but if the tips are new or near new, they only need a very little deburring (usually with a dremmel tool and stone). I just cut the 1" holed in the 3/8 plate for my bucket, and it only took 20-30 seconds with the dremmel to smooth it out. If i need a 1" finish hole, i set the cnc to cut me a 0.98" hole, then i grind it to fit.
I wish i could afford a laser....but that will never happen.
Straight cuts are usually better than full circles, but id rather have to use a dremmel than a drill press.
/ Cutting Tools #27
For cutting straight-line 1/2'' thick and less I use the Evolution circular saw. It works great and doesn't leave a mess in the work area. When you are done, the pieces are clean and ready to assemble. Cost is a lot less then investing in a plasma cutter if you don't plan on doing a lot of cutting.
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
