Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
   / Cutting / Groving / Siping R-4 for snow #451
Ok, been following this thread since its start and have trying to get up the nerve to carve up my expensive tires. After this last storm with its 30" of snow I figured it was time to give it a try before resigning to the occasional chain usage (which I don't want to use on asphalt) I only did one front tire and it took longer than I anticipated but attributed it to the air temp (40) and it being my fist try at it. I put some dots on the tire for reference but did it mostly freehand. 3 more to go :)
Looks great!!!
   / Cutting / Groving / Siping R-4 for snow #452
Any follow up pictures?
Looks like your doing a great job, wondering how much difference it makes?
   / Cutting / Groving / Siping R-4 for snow #453
Any follow up pictures? Looks like your doing a great job, wondering how much difference it makes?
I completed the 2nd front tire Sunday, naturally it went much smoother due to a little exp & warmer temperatures. Prior to that I did get a chance to do a little FEL work with the one front left tire done. It was in the shadiest part of my drive way and very icy and I want to say it helped because the tires usually spin a good bit when changing directions. I didn't see that happening as much. It looks as though that may be the last time this winter I'll get to test them because it 60 today. That being said I like the theory & early results so far to probably do the back tires at some point. I will try and post a pic of the other tire when I get a chance. Hope this helps.
Matt
   / Cutting / Groving / Siping R-4 for snow #454
Here's a pic of the 2nd tire, took a 1/3 of time as the 1st.
   / Cutting / Groving / Siping R-4 for snow #455
Boris1, looks great. Stanley
   / Cutting / Groving / Siping R-4 for snow #457
   / Cutting / Groving / Siping R-4 for snow #458
I don't know that I'd say that but thanks
If you said it, it'd be interpreted as bragging- but you ARE allowed to think it.
I said it, and therefore in my unhumble opinion, it is entirely true.
Finally- you're welcome.
Thank YOU for giving me some new ideas about how to possibly manage grooving my tires in an even and measured manner- as opposed to the wavy lines I expect to see
[No, I still haven't gotten that magical coin yet...].
The roundtuit...
   / Cutting / Groving / Siping R-4 for snow #459
Wow! Indeed nice job Boris... you said in an earlier post you used white dots and 'mostly' freehand. Did you sometimes use a straight edge? If so, did that speed things up? Seeing yours I am encouraged to try myself if I can get my hands on a tool.
   / Cutting / Groving / Siping R-4 for snow #460
See- told you so!
:thumbsup:
Own it, man, own it...
:mischievous:
Believe you me, not all commentary of mine [nor anyone else's] here is necessarily complementary*- although I personally DO try to remember the golden rule.
*Hence the lack of [m]any project picture posts by me...
I know that I'm at best a hack artist & chainsaw carpenter.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
METAL STORAGE TANK OIL DRUM (A58374)
METAL STORAGE TANK...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2024 Chevrolet Tahoe SUV (A56859)
2024 Chevrolet...
2017 GMC SIERRA 1500 (A58214)
2017 GMC SIERRA...
