Cutting Grass With R4's
/ Cutting Grass With R4's #1
garbageman
Orange County, NY
Kubota 7500
Cutting Grass With R4\'s
I own a Kubota B7500 with R4's and a 60" RMM which a get a good cut from. My problem is making turns and the front tires cutting in to the grass. My dealer wants $800 for a set of turfs. Does anyone have turfs on a 7500 or similar tractor and how are the results. I was thinking of selling the RMM Befco C30 and just have a dedicated lawn tractor. The mover is one year old and in excellent condition. What is it worth? What do you think?
Thanks,
Ray
/ Cutting Grass With R4's #2
Re: Cutting Grass With R4\'s
I have a B7500HST w/ R4's and a LandPride 60" RFM. How much pressure are you running? I just checked my R4 fronts and they have 11.5#. The type of soil and amount of moisture in the ground probably affects the performance of the tires. Unless I have the B7500 in 4WD or am running around with the loader on, mine isn't hard on the grass..............chim
/ Cutting Grass With R4's #3
Ray,
I can't comment on your particular set-up but I can say that turf tires will not necessary solve your problem. I have turfs on my 755 and I can tear up grass in turns.
Jeff
/ Cutting Grass With R4's #4
I'm not familiar withthat set up, but does your tractor run in 2wd? If so this can play into the way the wheels turn while cornering. I mow my lawn with R4's, but I have to be in 2wd so I don't rip up the lawn in corners.
Chim,
I have been running it with the loader on. Matter of fact the loader hasn't been off the tractor it's been so useful. What is it like removing and putting the loader back on. Any tips?
Thanks,
Ray
/ Cutting Grass With R4's #6
Sequence re. loader in Kubota manual isn't bad, but prior threads on TBN really covered the topic well. Anyhow, getting the loader off is not difficult, but if it isn't on level ground, putting it back on can take a bit of patience. I doubt the loader is a major problem, and would favor, as others, the usual culprits - 4WD, wet ground, tight turns. Minimize the aforementioned, and if you've still a problem, try the loader removal.
I've an L4300 with a FEL, R-4's, and a 72" Woods brush cutter - if I'm not leaving major ruts, you sure as heck shouldn't be.
No, I don't leave ruts in the grass, just cut it up while making turns. When I make (what I consider too wide turns) the grass is fine, but I feel I waste alot of time doing that. It seems to be the edge of the tires that do the damage. Looking at the front tires they are "pigeon-toed", thinking that may be the answer. The dealer says thats the way it's built. I'll try removing the FEL and see what happens.
Thanks for the advice,
Ray
/ Cutting Grass With R4's #8
Cisco gave you a good explanation. I keep my tractor and loader in the garage, so there's the benefit of working off of a level surface. One biggie after unhooking the loader is to shut the engine down and work the joystick till all movement has stopped before disconnecting the hoses. This makes it easier to pop the quick-disconnect fittings back together when remounting the FEL.
I just put my FEL on for a 5 minute project tonight, and removed it again. After you do it a few times, it really takes less than 2 minutes.
If you remove the FEL, you will notice quite a difference in the way your tires perform on grass while making turns. It also makes the tractor much more maneuverable..................chim
Thanks for all the helpful advice! I'll let know how it goes.
Ray
/ Cutting Grass With R4's #10
Should be a lot better with the loader off. I don't do finish mowing with my tractor, but I take it off for a number of reasons - one of which (that would apply to you) is that the front end doesn't dig in as much during turns. Also allows me to make larger radius turns, which would prevent the wheels from digging in. But I don't think that going to turf tires would fix your problem - just change the shape of the ruts in the grass /forums/images/graemlins/laugh.gif. Big tractor for mowing the lawn /forums/images/graemlins/grin.gif.
/ Cutting Grass With R4's #11
Make SURE you are not in 4WD. bcs
/ Cutting Grass With R4's #12
I have the same setup - B7500, R4's, 60" MMM. Can't really avoid digging up the lawn a bit.
I swap back and forth between 2wd and 4wd alot when mowing. I find that 4wd is a tad bit smoother due to the bumpiness of my lawn, so I try to keep it in 4wd. When turning, I flip it into 2wd.
One problem with 2wd is that you have to be careful to not spin the wheels. If you have to backup, and the grass is slightly wet, or you're on enough a slight incline, the back wheels can spin and dig up the grass a bit if you're in 2wd, so I usually flip it into 4wd in those types of situations.
The FEL was taken off and that did the trick. A nice improvement. Thanks for all of the good advice.
Ray
2019 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59911)
2019 HINO 268 4X2...
2014 International WorkStar 7500 T/A Dump Truck (A61573)
2014 International...
2022 EZ-GO ELITE...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
