CUT Low Loader Lift Capacity
   / CUT Low Loader Lift Capacity #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Hoping to buy a new HST Loader Tractor - full sized compact frame.
Kubota has always been at or near the top of my list.
However while researching, the lift capacity posted for the various Kubota CUT's are significantly LESS than most of the competition.
Trying to get at least 2,000# lift capacity without buying an 'M' Series. Budget is around ~ $30,000.
Any insights?
TIA
Yooper Dave
   / CUT Low Loader Lift Capacity #2
Kubota MX series. The MX Series is now comprised of two models, the MX5400 and the MX6000, ranging from 55.5 to 63.4 gross engine horsepower and both available with an optional factory cab.
If you will be lifting one ton loads higher than 36" routinely you would be wise to spend for the additional weight and width of an M series. SAFETY FIRST.
Kubota LA1065 Loader (MX)
Height (to pin):111.2 inches
282 cm
Clearance, dumped bucket:85.5 inches
217 cm
Dump reach:26.1 inches
66 cm
Dump angle:46°
Reach at ground:78.1 inches
198 cm
Rollback angle:42°
Breakout force (at 500mm):3102 lbs
1407 kg
Lift to full height (at pin):2275 lbs
1031 kg
Lift to full height (at 500mm):1691 lbs
767 kg
Bucket width:72 inches
182 cm
Kubota BH92 Backhoe
Backhoe type:Kubota BH92 Backhoe
Transport height:100.1 inches
254 cm
2-Foot flat digging depth:109.8 inches
278 cm
Reach from pivot:150.4 inches
382 cm
Loading height:84.3 inches
214 cm
Bucket Rotation:180
Page information
Last update:February 28, 2021
Copyright:Copyright 2021 TractorData
Contact:Peter@TractorData.com
My local Kubota Dealer (30 min. away) has a 2019 L4701 with rim guard and a few hundred hours on it.
He is going to set up some pallets with known loads on them so we can see how much can actually be lifted.
Due to the industrial treads on the tires, chains will be added to the front tires so I can still plow the driveway.
Yooper Dave
   / CUT Low Loader Lift Capacity #4
L4701 has a relatively weak loader for it's size,as suggested the Mx series should lift your intended loads.Kubota loaders are roughly 2 times the number on the loader(I.E. 854=1708 lbs.).
Also there is "standard" for determining capacity across the manufactoriers ,some measure at the pins ,some at bucket edge ect.
   / CUT Low Loader Lift Capacity #5
The L4701 is 4" to 7" narrower in wheel/tire spread than an MX, depending on tire selection. A BIG decrease in platform stability. The LA765 Loader on an L4701 is rated for about 1,300 pounds lift to full height, AT THE PINS.
The Kubota dealer is going to set up some pallets with known loads on them so we can see how much can actually be lifted.
Likely 1,300 pounds lift of LADEN PALLETS 6" off the ground, 1,150 pounds at 36", lift capacity decreasing rapidly with additional height.
   / CUT Low Loader Lift Capacity #6
And note it has been reported on TBN a while back that many Kubotas straight from the dealers have had real world performance poorer than specs. It seems they were "cranked" down, perhaps to prevent failure. All I read about were able to be "cranked" back up and performed well.
So when you test it at the dealer find out what pressure it's running at. They may have one "detuned" or tuned up.
   / CUT Low Loader Lift Capacity #8
I’m with Jeff on this one. If you want 2,000 lbs go with MX or an M. GL with bigger loader should do it too, but expensive.
Here‘s the CA specs for the 1154E
The 'M' or 'MX' is simply too big for me. If the loader test fails I will give the LS MT342H dealer a call. His tractor has a load rating of 2,680#. The price would be less as well.
Regards,
Yooper Dave
   / CUT Low Loader Lift Capacity #10
LS MT342​
Dimensions
Wheelbase:73.2 inches
185 cm
Length:133 inches
337 cm
Width:62.5 inches
158 cm
Height (ROPS):95 inches
241 cm
Height (cab):90 inches
228 cm
LS LL4106 Loader
Loader weight with bucket:1045 pounds
Height (to pin):94.4 inches
239 cm
Clearance, dumped bucket:64.4 inches
163 cm
Dump reach:16.7 inches
42 cm
Dump angle:52°
Clearance, level bucket:83 inches
210 cm
Rollback angle:41°
Breakout force (at pin):4063 lbs
1842 kg
Breakout force (bucket):2660 lbs
1206 kg
Lift to full height (at pin):2680 lbs
1215 kg
182 cm
I am 74 years old and recognize my relative fragility.
I know not your age but personally I would not consider it safe to lift 2,500 pounds with a 62.5" width tractor, except on an infrequent basis, on swept, smooth, flat and level pavement.
The LS price would be less.
Research a wider model LS.
This issue isn't brand vs brand. It is physics.
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
7046 (A50322)
7046 (A50322)
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
