Cut Height Changes by Itself
/ Cut Height Changes by Itself #1
rwsr50
Anybody have problems with the cut height adjustment changing all by its ownself?
My Son told me it kept changing on him. When I used the tractor the next time I kept an eye on it. It only did it twice for me and seemed like it was only after I raised the deck momentarily with the hydraulic control to clear some high spots and avoid scalping.
Another question. Should the knob index on the "points" or on the flat side of the pie shaped wedge with the number in it? In other words, should it stop on the line inbetween say 2 and 2.5, or stop in the middle of the 2.5? Mine wants to stop more on the lines.
Oh yeah, sorry, I have a BX 2230.
/ Cut Height Changes by Itself #2
I have a BX2200 w/ a 60" mmm, mine "clicks"/"locks" in on the flats. and I can't say it has ever moved on its own in the 110 hours that I put on it
/ Cut Height Changes by Itself #3
My 2230 has positive " clicks " also and stops sorta between the numbers, with the number to the right being the cutting height. Are you saying that the dial changes position? I have never heard of that happening, but anything is poss. Hey, aren't you the guy with the "rust bucket?"
</font><font color="blue" class="small">( Hey, aren't you the guy with the "rust bucket?" )</font>
Yup, that's me. Maybe that's the problem. Maybe that's one part that didn't rust yet and is still too slick and smooth to stay put, ha, ha.
Yes, mine works just like you described with the "kinda" clicks and stopping between numbers. It has changed by itself though at least twice for me and I don't know how many times for my Son.
When it did it for me it went lower, which is what you'd expect I guess due to gravity and all. Like I said, when it did it for me, it seemed to be right after I had lifted the deck to clear an obstacle. I didn't touch the adjustment knob.
/ Cut Height Changes by Itself #5
</font><font color="blue" class="small">( Anybody have problems with the cut height adjustment changing all by its ownself? )</font>
Maybe what you've really got is a KuBOOta Bx2230? /forums/images/graemlins/shocked.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
Sorry, couldn't resist! /forums/images/graemlins/blush.gif /forums/images/graemlins/smirk.gif
/ Cut Height Changes by Itself #6
I used to have this happen all the time.
My yard is fairly bumpy, and I think if I get going too fast and the deck starts bouncing around a bunch, the height will change. Unfortunately, I usually wouldn't realize it until I'd scalped the yard for a couple laps.
My solution has been to always tighten the "drop rate" knob next to the deck height knob. This way, if the height knob should change, the deck will be 'locked' at the height you really want. Interestingly, ever since I've started tightening the "drop rate" knob I've never had the deck height setting change.
You may also want to check that you don't have the gage wheels too low also.
Hey, I was just thinking after Rainbow's post above, maybe I should change my handle to <font color="orange"> </font>"Rust Bucket" <font color="black"> </font> ha, ha.
Good idea on tightening up the drop rate knob. I'll give that a try. My yard is pretty bumpy too, but I usually mow at a speed that doesn't cause the equipment to get bounced around.
My wheels are set with a 1/2" clearance under them just like the book says.
I'm sure you guys will get me educated on this thing before too long. Thanks.
/ Cut Height Changes by Itself #8
Hi "rustbucket" my new Bx2230's knob works just like yours'. Sometimes it aggravates the hell out of me. Also My cutting height is 1/2 inch less than what the dial is showing when I measure the blades off the concrete.
stumper
/ Cut Height Changes by Itself #9
If you have the 5' deck the wheels are set according to the cutting height, and so far for me the wheels have prevented any scalping in my yard.
/ Cut Height Changes by Itself #10
If you have the 5' deck then it is self-leveling. Page 15 in your manual shows that you adjust the wheels differently for each cutting height. If this is the case and you leave the wheels the same all the time it may account for the difference you mentioned. If not then, hey, who knows.
I checked the adjustments out on my deck and it was way off front to back. I leveled that up.
Next I checked the all the way up position in relation to the stop, and mistakenly adjusted that with the lift link rather than the double nut in the back. So, once I discovered the errors of my ways, I readjusted again. I hadn't used it in between.
When I adjusted the second time, since I had to readjust the lift links anyhow, I set the knob on 2", then took a piece of 2" square steel tubing, and adjusted til the blades were even with it. All this was done on a concrete garage floor. So, mine should be pretty good now.
But, who really cares if the dial says 2" and it is actually cutting it 3". Just adjust it til the grass is the length you want it and don't worry about what the knob says. Just remember what you set it on for reference in case you change it, or the ghost of KuBOOta changes it, ha, ha.
As far as the wheels, I set mine to be just clear of the garage floor with the deck at 2", which is where I cut. That is one hole lower than the chart for the self-balancing deck shows, but I figured it would be better a little too low than too high, as far as scalping goes. Maybe when I mow tomorrow I'll try them up one hole and see what happens.
Well, I mowed again yesterday. I started out by setting the wheels where Kubota tells you on their chart for the self-balancing 60" deck. Contrary to my statement above, I actually had my wheels one hole HIGHER than the chart recommendsk, not lower.
With the wheels lower, the adjustment was changing itself constantly, so I stopped and took them up one hole. That puts them just off the concrete floor with the deck in the 2" cutting height I use. The adjustment stayed put much better, but still changed once in a while. My deck may be a little lower than 2" after I adjusted it and maybe that's why the chart setting for 1.5" works better, I don't know.
I think when the wheels hit the ground, it is taking the weight off the stop and it is free to vibrate or bounce into a different setting. At any rate, it is a very annoying problem. Having to remember to keep checking the adjustment takes away from the pleasure of seat time.
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
CASE CX160C EXCAVATOR (A65053)
CASE CX160C...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
