Buying Advice CUT buying advice
/ CUT buying advice #21
Great/heavy frame tractor, yet compact in size.
Great deal. Go for it.
/ CUT buying advice #22
Working on a deal on an L3240 gst with 70 hrs. No FEL or attachments. Dealer will add a new LA724 loader and 6' med duty bush hog for $19,700. I think it's the best package yet.
k
Nice solution, that should take care of previous concerns and model comparisons.
/ CUT buying advice #23
I think you'll be happier with this one than either of the others you were cnsidering.
/ CUT buying advice
I made the trip to go over the tractor today.
The bad:
Cosmetically its not as pretty as I was hoping for a 70 hour tractor. Not abused, or really even too many signs of use, but its faded and there is rust here and there. Looks like it may have had a canopy or been under a pole barn, but it wasn't kept indoors.
It's a 2009. Again, with 70 hrs I was hoping it would be a 2012 or 2013.
It has the original oil in it. The dealer noted that it had a gray filter. He called the owner (its on consignment), who confirmed that it's never been changed. How someone can think that 7 years is a reasonable amount of time to leave oil in, regardless of hours, is beyond me.
The good:
Part of the reason its had the same oil in it for 7 years is because the owner seemingly forgot about the machine. There was warranty work done in 2009 for a faulty GST valve (wouldn't go into high gear) and the rubber boots on the front axle (linkage?) where it was documented at 19 hrs. According to the dealer the owner, an elderly man, has a larger tractor with a loader- which is why he purchased this one without one. Not sure what this one was used for, but it wasn't used much. The molding marks on the edges of the rear tire tread are intact, as are the little fins left from molding between the tread on the front and rear tires. I asked if the hour meter could be manipulated, and he said not without a new $1,000 panel- and no such purchase was attached to the serial number.
Everything works perfectly
Price. We're down to $19,500 WITH oil/filter change and fuel filter change. Hydraulic filter has been changed (probably during warranty service.) The dealer is also replacing the 3pt pin that currently has a hitch pin in it. The breakdown is $12,500 for the tractor, $5,000 for the LA724 loader, and $2,000 for the 6' land pride medium duty rotary cutter with slip clutch.
Interest rate. The implements are 0% for 48, and combining them with the 4.98% used tractor rate put me at 3% for the package. 5% is the best I've seen on used equipment from a dealer, and what I've read about financing a private purchase is 6% with "exceptional" credit.
The dealer. This is the first one that has been straight with me. I sell prison sentences for a living, so I know when somebody is giving me a pitch. This guy gave me the sellers bottom line the first day I called him. After I negotiated on price HIS numbers moved on the implements, the seller's stayed the same. He originally told me he'd need money up front so he wouldn't get stuck with the loader, then made the agreement today on a handshake.
I've done a lot of shopping and I haven't seen anything better for the money. The only new tractor that I'd buy at that price is the L2501 (with hydro now ;)). Total cost would be roughly the same. My biggest concern, obviously, is 7 year old oil. If it weren't for that I would have insisted that he take my down payment today. He hasn't ordered the loader yet, so I can still sleep on it.
/ CUT buying advice #25
Even with the issues mentioned, it looks like a good buy overall and a little TLC will probably bring back the color.
/ CUT buying advice #26
This has been a very well written thread and the tractor you found is a very good find. Our kubota was a new old stock and roof was a bit faded buts lots of elbow grease fixed that. TripleR is a wealth of information as are many others on here. Enjoy your tractor time as you will come to enjoy the peace and solitude it affords. I also believe there are several others on here who share similar employment fields
/ CUT buying advice #27
Kubota paint does seem to have a tendency to fade. As for the oil, as I recall its recomended for the oil to be changed at 50 hours. So I guess at 70 I wouldn't see that as a huge biggie. As long as it hasn't been used I wouldn't let the oil being old bother me. Is the dealership going to give you any kind of warranty?
Imo a nice tractor at a great price. The mower seems like a fair deal too. Having not priced out Kubota loaders alone, it seems a little high for it, but I don't have experience to draw from either.
Bottom line, I don't see any reason not to go for it. A fair deal, it fits your needs and hopefully your budget too.
/ CUT buying advice #28
Clean it, wax it, get all the fluids changed, put some black graphite paint on the rusty exhaust areas, and enjoy. When they change the oil, you want to examine it for signs of water or other stuff that shouldn't be there. That is nice tractor!
/ CUT buying advice #29
Good advice ^^^.
Can not comment on the price but the tractor looks good and I would not worry too much about the 7 yr oil. While all of us would have changed it out long ago I don't see it causing problems in a 70 hour machine. I would change all the fluids, filters and battery then you should be good to go.
/ CUT buying advice #30
Did a little checking. tractorhouse has a used 2010 LA724 FEL for $3750. So yours is new and they are putting it on so that price of 5k seems fair. I also looked at an old thread on here and your 3240 with the LA724 FEL alone was priced at 21k back in '11. This didn't have the LP mower in the price either. So all in all I'd say jump at this deal.
/ CUT buying advice #31
I would run away from a tractor that hasn't had the oil changed in 7 years. WTF was that guy thinking. You don't change the oil just based on hours you also change it at least once a year regardless of hours.
/ CUT buying advice
It seemed like it was still the right deal- but thanks to those who confirmed it. I'm not ignoring the dissenting opinion, but at least with this one I know the good and bad. I've looked at a couple of other 200 hr machines (one of which looked like ****) and I have no idea if they were maintained. Both the salesman and a tech spoke separately about the owner's advanced age and likelihood of him running any equipment hard and fast. Thanks also to Jeff9366 for the dealer referral. It was worth the drive. I'll update the post when I pick it up in a week or two.
/ CUT buying advice #33
The thing that surprises me about the oil is that the dealership didn't drop the oil as soon as the tractor came on the lot, before they ever showed it. I'm glad they were honest about it which is far far more than many would be. Dealers and private parties alike.
I'm one that changes according to hour use and mileage. I pretty much put those hours on every season anyway. But I don't lose sleep if my tractor goes 16-18 months between the change if the hours weren't used.
/ CUT buying advice #34
While it would have been better to change the oil at 50 hours, or after a year or so, if the oil hasn't been diluted with water, and the filter is doing its job, it should be fine. If the tractor was 18 months old, and had 70 hours, we wouldn't be having this discussion, so sitting for a couple years without being used might not hurt anything. Heck, change the oil, and change it again after another 50 hours, if it makes you feel better. If it runs fine, it probably isn't damaged.
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
Vertical Steel Well Tank (A61570)
Vertical Steel...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
2010 Nissan Rogue SUV (A61569)
2010 Nissan Rogue...
