Curtis Cab Roof Work Lights
   / Curtis Cab Roof Work Lights #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
Would someone recommend replacement Curtis Cab Roof Lights for my JD 4310. Just not sure if I should go with Halogen or LED work lights . . . primarily for snow blowing at night.
Thanks,
FredSG
   / Curtis Cab Roof Work Lights #2
LED all the way.. They use little power, last a long time and are very bright.. A 4inch flood on all four corners is what I use, lights up the work area like daylight..
Atsah,
Which LED Work Lights are you using? Where is Maine, as you listed?
FredSG
   / Curtis Cab Roof Work Lights #6
Atsah,
I want to hook the lights you recommended to a 6 Rocker Switch Panel - one Rocker is the main and each of the other Rocker switches control other electrical devices on my 4310 . . . I have a 20 amp fuse on the power line going to the Rocker Panel. Will the LED lamps work with this set up . . . any idea?
FredSG
   / Curtis Cab Roof Work Lights #8
I don't see why not, they draw very little.. I hooked all four to my headlight switch so when I turned on my headlights they all came on..
Atsah,
Thanks so much for taking the time to reply . . . very much appreciated.
Off to Amazon!
Fred
   / Curtis Cab Roof Work Lights #10
Atsah,
Off to Amazon!
Fred
Pm me if you have any further questions when you get them, good luck...
Mark
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A51692)
2021 Mercedes-Benz...
2009 40ft High Cube Refrigerated Storage Container (A51691)
2009 40ft High...
2011 Chevrolet Suburban SUV (A51694)
2011 Chevrolet...
2016 Kubota RTV-X900 4x4 Diesel Utility Cart (A51691)
2016 Kubota...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
