Curtis Cab Roof Work Lights
   / Curtis Cab Roof Work Lights #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
Would someone recommend replacement Curtis Cab Roof Lights for my JD 4310. Just not sure if I should go with Halogen or LED work lights . . . primarily for snow blowing at night.
Thanks,
FredSG
   / Curtis Cab Roof Work Lights #2
LED all the way.. They use little power, last a long time and are very bright.. A 4inch flood on all four corners is what I use, lights up the work area like daylight..
Atsah,
Which LED Work Lights are you using? Where is Maine, as you listed?
FredSG
   / Curtis Cab Roof Work Lights #6
Atsah,
I want to hook the lights you recommended to a 6 Rocker Switch Panel - one Rocker is the main and each of the other Rocker switches control other electrical devices on my 4310 . . . I have a 20 amp fuse on the power line going to the Rocker Panel. Will the LED lamps work with this set up . . . any idea?
FredSG
   / Curtis Cab Roof Work Lights #8
I don't see why not, they draw very little.. I hooked all four to my headlight switch so when I turned on my headlights they all came on..
Atsah,
Thanks so much for taking the time to reply . . . very much appreciated.
Off to Amazon!
Fred
   / Curtis Cab Roof Work Lights #10
Atsah,
Off to Amazon!
Fred
Pm me if you have any further questions when you get them, good luck...
Mark
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53473)
2012 KINZE FLAT...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
1990 Nitro Tracker 165TF Bass Boat with S/A Galvanized Trailer (A51694)
1990 Nitro Tracker...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
