Curtis Cab Roof Work Lights
   / Curtis Cab Roof Work Lights #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
Would someone recommend replacement Curtis Cab Roof Lights for my JD 4310. Just not sure if I should go with Halogen or LED work lights . . . primarily for snow blowing at night.
Thanks,
FredSG
   / Curtis Cab Roof Work Lights #2
LED all the way.. They use little power, last a long time and are very bright.. A 4inch flood on all four corners is what I use, lights up the work area like daylight..
Atsah,
Which LED Work Lights are you using? Where is Maine, as you listed?
FredSG
   / Curtis Cab Roof Work Lights #6
Atsah,
I want to hook the lights you recommended to a 6 Rocker Switch Panel - one Rocker is the main and each of the other Rocker switches control other electrical devices on my 4310 . . . I have a 20 amp fuse on the power line going to the Rocker Panel. Will the LED lamps work with this set up . . . any idea?
FredSG
   / Curtis Cab Roof Work Lights #8
I don't see why not, they draw very little.. I hooked all four to my headlight switch so when I turned on my headlights they all came on..
Atsah,
Thanks so much for taking the time to reply . . . very much appreciated.
Off to Amazon!
Fred
   / Curtis Cab Roof Work Lights #10
Atsah,
Off to Amazon!
Fred
Pm me if you have any further questions when you get them, good luck...
Mark
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
John Deere Z997R (A50123)
John Deere Z997R...
Polaris Side by Side (A50324)
Polaris Side by...
2010 Ford Transit Connect Cargo Van (A53117)
2010 Ford Transit...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
2024 Polaris General XP 1000 Premium  (A52384)
2024 Polaris...
