Cub hydro system
/ Cub hydro system #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
Is there a website with good service info on the Cub's hydro system. My latest 1872 project (auction) is leaking a bit, I believe from the hydro relief valve. I'm hoping to power wash and isolate the source, but then what.
I noticed in the parts diagram there four different relief valves or maybe the ported and non ported serve a different purpose?
I hate oil leaks!
It also wants to creep forward, I guessing some trunnion adjustment is in order?
Thanks,
Curt
/ Cub hydro system #2
You can download the 1862 (very similar model) service manual here:
IHRegistry Home
The hydro creep is due to the linkage to the pump needing adjusting, which is very common on older hydro tractors. The leaks are likely to be your typical seals and gaskets.
-Fordlords-
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
Denis Cimaf Hydraulic Mulcher Skid Steer Attachment (A66734)
Denis Cimaf...
2015 Ford F-250 Knapheide Service Truck (A66736)
2015 Ford F-250...
2016 JAYCO JAY FLIGHT CAMPER (A67714)
2016 JAYCO JAY...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
