cub cadet snowthrower modification
/ cub cadet snowthrower modification #1
beckyb
I have a model 149 hydrostatic cub cadet lawn tractor (1970's). I also have a cub cadet model 195350100 snowthrower which is approx. 15 years newer. How can I adapt this snowthrower to my tractor? Cub Cadet said it won't work but I believe it can with customizing. Help!
/ cub cadet snowthrower modification #2
Wow! first I'd start by putting the larger wheel bearings in to carry the extra load because you are gaining a lot of weight. The belt width for the 350 model(that is the newer model number) vs the QA42 for the original blower is different. I haven't played with your new combination but I am inerested in if it is possible or can be adapted.
/ cub cadet snowthrower modification #3
Is the 149 a narrow frame? If so, I have a 36" wide blower to fit it - if you are interested.
Rich
/ cub cadet snowthrower modification #4
Many of the older single stage units were adaptable. But I tink a 149 is a little over kill for a 36" blower.
/ cub cadet snowthrower modification #5
I think She would be best served getting a QA42 for her machine, but do it quick because whats around is going quick....less adaptation headache, and the QA42 works very well ( have it on a 125)
Good luck!!
/ cub cadet snowthrower modification #6
Does anyone have a picture of the adaptor to get the belt from the engine pulley to the snowblower?
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
Covington TP-66 Planter (A64127)
Covington TP-66...
