cub cadet snowthrower modification
/ cub cadet snowthrower modification #1
beckyb
I have a model 149 hydrostatic cub cadet lawn tractor (1970's). I also have a cub cadet model 195350100 snowthrower which is approx. 15 years newer. How can I adapt this snowthrower to my tractor? Cub Cadet said it won't work but I believe it can with customizing. Help!
/ cub cadet snowthrower modification #2
Wow! first I'd start by putting the larger wheel bearings in to carry the extra load because you are gaining a lot of weight. The belt width for the 350 model(that is the newer model number) vs the QA42 for the original blower is different. I haven't played with your new combination but I am inerested in if it is possible or can be adapted.
/ cub cadet snowthrower modification #3
Is the 149 a narrow frame? If so, I have a 36" wide blower to fit it - if you are interested.
Rich
/ cub cadet snowthrower modification #4
Many of the older single stage units were adaptable. But I tink a 149 is a little over kill for a 36" blower.
/ cub cadet snowthrower modification #5
I think She would be best served getting a QA42 for her machine, but do it quick because whats around is going quick....less adaptation headache, and the QA42 works very well ( have it on a 125)
Good luck!!
/ cub cadet snowthrower modification #6
Does anyone have a picture of the adaptor to get the belt from the engine pulley to the snowblower?
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
