Cub Cadet 2160 engine
/ Cub Cadet 2160 engine #1
Livinontheedge
Trout Valley,IL
Cub Cadet 2160
I need to replace my engine on my 2160. I've found a 16 and 18 hp Briggs Vanguard engine but don't want to spend $1000+. Any ideas on alternative engines or a good place to find a new or used engine that can be used in the 2160?
/ Cub Cadet 2160 engine #2
Why do you need to replace? A rebuild or more often just head gasket may be all it needs.
It broke the crank shaft and the case and had other internal damage.
/ Cub Cadet 2160 engine #5
Did you try looking for a donor tractor ? It seems when I look I can buy a whole tractor for less than what people are asking for just an engine or deck. I did that when I needed a new deck, but ended up rebuilding the donor tractor and using it as well.
/ Cub Cadet 2160 engine #6
Is your tractor shaft drive/hydro? If so then you need an extra expensive motor that is so designed. Trust me. I know from experience.
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
4" Makita Disc Grinder (A62613)
4" Makita Disc...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
Takeuchi TB225 (A62177)
Takeuchi TB225...
