Cub cadet 1864 hyrostat problem
/ Cub cadet 1864 hyrostat problem #1
billsranch
Petrolia, ON
Cub Cadet 1864, Husqvarna CZ1748 (2006), Ford LGT125 (1980), MM-U (1953)
I have a CC 1864 and having problem regulating the forward and reverse speeds. I have to move the hydostat lever ahead almost 3/4 of the way before the tractor will move. Then once it gets moving, I have to pull the lever back near neutral or else it will go like the wind ... in high speed. This first started last year with problems not going into reverse at all. I adjusted the linkage to make it back up better,however it also will go into high speed in reverse until you pull the lever back towards the neutral position. I am constantly moving the lever forward and inching it back after it gets going.
Anyone have a similar problem? If the hydrostat needs rebuilding can this be done by the amateur or should it be sent away?
Thanks,
Bill.
/ Cub cadet 1864 hyrostat problem #2
I'd wonder that you adjusted the right linkage! The other thing that it could have been to begin with would be the poppet valves onto of the transmission.
/ Cub cadet 1864 hyrostat problem #3
You can click here and find the service manual for your model. Manuals There are instructions for adjusting the linkage in it.
Thanks for the link to the service manuals. I will take a look over the hydrostat section to see if I can tackle this myself. Looks like only the 1862 model is listed in the service guide, (says the 1864 replaces it).
Thanks,
Bill.
2011 GMC SIERRA 2500HD (A67714)
2011 GMC SIERRA...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
HEAVYEQUIPMENT OFFICE ITEMS (A68842)
HEAVYEQUIPMENT...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
