cub 2186 rear bagger
/ cub 2186 rear bagger #1
macklong
Idaho
JCB MIDI CX4, 1949 Farmall supper A, Polaris Ranger 900XP
Hi everyone new member here. I have a new 2186 I was thinking of buying a bagger for it. What I want to know is do the baggers work very good or do i need to purches the commercial bagger with the extra side mount blower motor?
/ cub 2186 rear bagger #2
</font><font color="blueclass=small">( Hi everyone new member here. I have a new 2186 I was thinking of buying a bagger for it. What I want to know is do the baggers work very good or do i need to purches the commercial bagger with the extra side mount blower motor? )</font>
I have the triple bagger on a 54 inch deck on my 3235 and it works very well. The only problem is cutting wet grass which will cause the chute to plug up. I have an acre lot and once when the grass was wet I had to remove the chute almost every loop around the yard to clean out the grass. That has only happened a couple times in 1 year of use.
Bob B.
/ cub 2186 rear bagger #3
I also have a 2186 with triple bagger, used last fall for leave pickup and this spring for grass clippings, It works great for me, unless you are mowing a very large yard I think this would do you fine. The only plugging up problem I have had is when bags get full and plugs chute, depending on amount of lkeaves on ground plan on dumping bags often, with grass I mow my yard-3/4 acre and dump 2-3 times
/ cub 2186 rear bagger #4
I have a 2 bagger on a 2180. They work great. They pack the grass in and fill to overflowing. The grass has to be pretty wet to plug. A trick is after use to take a hose to the inside of the plastic chutes. Spray them down and you'll a lot of the grass off the inside of the tubes. Keeps the velocity up.
Just make sure you've got a place to dump the clippings! /forums/images/graemlins/grin.gif
Ditch Witch Mixing System FM13V (A65579)
Ditch Witch Mixing...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
AGT SAII100 (A64127)
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
